Go to Post ... Better to treat everything like it's about to explode and be wrong than the other way round. - Bongle [more]
Unread 06-08-2008, 18:33
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
pic: 6 wheel omni directional with a suspension
Unread 06-08-2008, 19:44
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
Re: pic: 6 wheel omni directional with a suspension
if your only using two rods it seems that it would not be strong enough and it will be pretty loose you may have a problem with the frame bottoming out
Unread 06-08-2008, 19:55
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
Can mecanum wheels be backwards as long as the diagonal wheels are in sync?
Unread 06-08-2008, 19:58
EricH EricH is online now
Yes... but there are some ramifications to that, like it's now easier to spin you around. You may also need to reverse some code for going sideways.
Unread 06-08-2008, 20:34
wilsonmw04's Avatar
Coach
so what the difference between:
\ /and / \
which is right?
hmm, looking at this again and the left one would tend to turn when the right one wouldn't? Interesting, I never thought of that until I looked at them side by side.
Unread 06-08-2008, 20:41
Typically, the "O" pattern is used. The "X" pattern may also be used. (When seen from the bottom; top is the opposite.)
Unread 06-08-2008, 21:30
joeweber's Avatar
Coach team 1322
I am not sure exactly what you are saying far as bottoming out. When we build the robot base it would be secured the length of the rods which are tubes. The base will most likely cover the whole empty area between the drives. We are using tubes (which we may increase the size) so we can slide the bumper bolts into the tubes and than slide pins into them to hold.
http://www.team1322.org/ideas.htm for a side view of the suspension.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 06-08-2008, 21:37
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Rather than increase the size of the tubes, you could also rivet lightweight honeycombed fiberglass or 1/16" sheet aluminum to the bottom, or 6" strips of either. It will greatly increase the rigidity of the two frame segments while also leaving the flex you want for suspension should the tubes not be enough.
This control system is straight up intriguing. The matlab plots are all obscured when the normal unit vector controls are put on it, though I may have the omni wheel's equation incorrect. I hope this succeeds; it will be as fascinating as 'twitch' drive to figure out.
GitHub
Unread 06-08-2008, 21:42
wilsonmw04's Avatar
Coach
I'm wondering about how the rest of the robot is going to fit on this frame. As the front arm moves up, won't it force the rest up (and back) as well? I'd be afraid of the CoG with a frame like this. If the center was kept very low, I could see this working.
Unread 06-08-2008, 22:22
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Along with the previous comment, regarding upperstructures and other things that mount to this, what's going to happen with electronics? Having a flexing board seems like an electronic person's nightmare.
More reasons for it to be an electrical problem than a mechanical or programmers.
Unread 07-08-2008, 01:01
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
What happens to the rod when the front left wheel wants to go up and the front right wheel wants to go down?
--Madison--
...down at the Ozdust!
Unread 07-08-2008, 09:39
gorrilla's Avatar
AKA: adam spears
bottoming out refers to the frame hitting the ground
unless you have enough ground clearance when you accelerate wouldent you frame be so (snakish)? that it would move with every little bump or change in velocity i dont see how you could attach an upper structure to it
Unread 07-08-2008, 09:40
gorrilla's Avatar
AKA: adam spears
good point
Unread 07-08-2008, 09:59
JesseK's Avatar
FRC #1885 (ILITE)
... that it would move with every little bump or change in velocity i dont see how you could attach an upper structure to it
The manipulator mount problem is easy in concept to solve, but it adds weight. The main base of the manipulator would have to be fully supported by one of the frame segments (forward or rear) and the angled supports that attach to the opposite frame segment would have to be broken up into two parts that attached to a gas shock or compression spring in a "Y" formation. So rather than seeing one solid bar for the angle support, we would see a "Y" with the compression spring/shock forming the base of the Y. Note, not a "T" formation because a "T" wouldn't allow the frame to flex up and down.
CoG and stability would have to be tweaked, but it is definitely possible.
GitHub
Unread 08-08-2008, 07:41
joeweber's Avatar
Coach team 1322
The rods are pivot points only and do not move or flex. A base of the main part of the robot will be attached to the rods. The rods are only showed to tie the two halves together. The rods only need to be long enough to go from the base through the drive units to allow for the pivot. When built we would limit the amount of pivot needed for any ramps required. We could also connect pneumatics to lock down the suspension for any long reaching manipulator. View http://www.chiefdelphi.com/media/photos/31755 to get a better understanding of how the base would attach to the rods. One half of the drive unit has slots to alow for the movement of the suspension. If you look close at the drowing you can see the slot and hole.
pic: 6 wheel drive with a suspension joeweber Extra Discussion 18 07-08-2008 00:49
pic: 6 wheel drive with a suspension joeweber Extra Discussion 16 05-08-2008 00:32
pic: Holomonic (Bottom View) with Large Omni-Directional Wheel Kit nonother Extra Discussion 9 16-05-2007 00:26
pic: omni-directional hoverbot progress Tytus Gerrish Extra Discussion 11 08-01-2005 00:15
Omni Directional Wheels Will Seymour General Forum 3 11-01-2003 12:43
