Small/flat but powerful motors
Would anyone know where I could get small or not so bulky motors that are still powerful? It would also be nice if they weren't too expensive.
Re: Small/flat but powerful motors
banebots.com trossenrobotics.com are all places to get motors. how much power are you looking for? what is the application that these are going to be used in? thanks, vivek -Vivek |
I prefer going to banebots and picking a motor with a gearbox, very strong and lightweight.
What is the application? The more you can tell us, the more we can help.
The EV Warrior Motor is pretty powerful and light. Its rated for .378 hp and runs at 2.6 A at 12v. Pretty reasonable motor for most projects.
Then again we don't know what your building... A brushless Etek motor would be fun 15 hp at 200 Amps and 24-36 Volts. That thing could kill you ![]() |
Well basically... I'm building a robot! The robot is small and it requires a very low center of gravity. By doing this I need to place the motors and much of the electronics at the bottom of the bot. The problem is the motors we used for the 2008 competition were far too bulky to work out in THIS robot.
I just also realized I need to work out the battery as well... anyone know if it's possible to get a smaller battery that's practical for a competition? |
#7
But for some more sights try: allelectronics.com (generally filled with random awesome parts) solarbotics.com (they carry a bunch of excellent parts specifically for small robots) |
#8
In the end the battery choice will probably be based on the motors you're running, how much current they are drawing, how long the matches are and how much the robot has to weigh. |
#9
I would look at RC shops, like towerhobbies.com, given that the robot is in that size-range. There are literally thousands of options for motors and batteries.
#10
NiMH and NiCad rc-car battieries are better for high current, but will be larger and heavier. |
#11
I'm talking about a FIRST Robotics competition. I like experimenting rather than sticking to the "same old" in a season so I'm trying out different drive trains. As for the robot... thinking of how to describe it... well you know those egg shaped annoying baloon things you used to beat the crud out of as a little kid? You know the thing no matter how many times you hit them they just went right up? I'm basically building one of those that moves. It's meant to be a robot that's small+speedy and it can never be knocked over.
#12
Cool Idea. If you want it to be able to be knocked around, but never flipped over, a low CG is good, but the way the upper structure works relative to the chassis is really what is important. For instance A sheet of plywood has an extremely low CG (when flat), but I can easily flip it over. The real trick to the Bop-a-clown is that the curvature of the inflatable makes it so the CG can never be above a tangential surface unless you flip it over perfectly balancing the weight on top.
If you took the Kitbot chassis and shortened it into a box (approx. 24x24"), strapped a trackball to the top of it, you would have a good initial prototype, and likely wouldn't need any special motors or pancake batteries. |
#13
Low CG is right and make a 6 wheel drive but make sure the middle two wheels are square with the back and center wheels. Drop the center like this if you want:
http://www.chiefdelphi.com/forums/sh...988#post758988 and a 6 wheel drive is really good for power and pushing. |
#14
http://www.chiefdelphi.com/media/img...50bee6a3_l.jpg with this: http://www.chiefdelphi.com/media/img...f1b026fe_l.jpg |
| pic: Powerful Drivetrain - 418 | leeweek | Extra Discussion | 6 | 10-04-2007 19:18 |
| pic: The gearbox that makes us so powerful | keenanmolner | Robot Showcase | 6 | 20-02-2007 02:11 |
| Torque vs. Current in small CIM motors | robotguru1717 | Electrical | 2 | 08-01-2007 17:09 |
| Too Powerful cannon? | I Eat Robots829 | Chit-Chat | 15 | 03-02-2006 00:19 |
| pic: IT MAY BE SMALL BUT IT SURE CAN DROP TETRAS FAST | Saton472 | Robot Showcase | 3 | 18-03-2005 16:50 |
