Go to Post It's just a game. - artdutra04 [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 09-08-2008, 14:36
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
Help with Windows 2000
I messed up my dad's computer.
It's a Dell Inspiron 8100 running Windows 2000 Professional.
I was trying to set up a network between it and my laptop and I changed it from the domain it was on, to a workgroup that my laptop was set to.
Normally, I would think this wouldn't be a problem. However, I forgot to take into account that at his last place of employment, an IT guy made it so he had to log in and it was tied to the domain that I changed off of. Now we can't log in to Windows.
I have already tried booting into safe mode, but it still prompts the log in screen. There also appears to be no way to change anything other than user name and password on the log in window.
If anyone has suggestions as to how I can bypass the logging in part to change it back to the way it was, I would greatly appreciate it.
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
Unread 09-08-2008, 15:03
maltz1881 maltz1881 is offline
maltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant futuremaltz1881 has a brilliant future
Re: Help with Windows 2000
Not sure if this would help or not but can you take out the battery?
Unread 09-08-2008, 15:10
FRC Key Volunteer Trainer
AKA: CrazyNate
In safe mode, the login is looking for the local administrator account(despite the domain settings, there is still a local admin account). If you know the information to get into that account, you should be able to get yourself up and running.
Nate Smith
nsmith@smythsoft.com
Unread 09-08-2008, 16:35
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
First, check to see at the login screen if there's a text box with the old domain, and a dropdown menu that allows you to select the local computer instead. If that's there, attempt to log on locally, using the same user name and password.
If that doesn't work, and presuming that he owns the laptop (it sounds this way, but you wouldn't necessarily want to mess with a corporate computer), you'll probably want to try something like resetting the local administrator password with a SAM file editor. Try this for a summary, and this for the de facto standard tool for doing it.
Now, before you go doing that, ask whether NTFS encryption (the built-in encryption scheme in Windows, a.k.a. EFS) was not used on anything important. If it was used, you'll find that the encryption actually works, and you'll lose the data protected with it.
Also, if there's anything remotely important on that computer, you're going to want to consider making a backup image (i.e. copy of the data structure, not just the data) of the hard drive. That way, if you screw up, you won't lose it all. You'll of course need some way of reading that drive on another computer, and a way to run the imaging software. Maxtor MaxBlast is free, and works if you plan to plug it into a desktop that already contains a Maxtor, Seagate, or maybe Quantum hard drive. (Acronis TrueImage is the commercial version of that software that doesn't check to see if a particular brand of hard drive is installed.) Symantec Ghost works well for this too, especially the older versions.
Unread 09-08-2008, 17:59
FiM Volunteer
I've attached some pictures of the login screen and what you get when you try and log in.
Before this, my dad did not need to enter a password. All that was needed was to click 'OK' to log in successfully.
ID:	6771  Click image for larger version
Unread 09-08-2008, 19:19
FiM Volunteer
Thanks a bunch Tristan, your suggestion of the password reset tool worked great and fixed the problem!
Since the problem is fixed, a mod can lock or close this thread.
Help Getting rid of Spyware/Windows XP help George A. Chit-Chat 9 17-02-2007 14:35
Windows 2000 & XP Pro Edition Help Raven_Writer Chit-Chat 4 25-02-2004 19:30
Heck Freezes Over: Windows 2000 & NT Source Code Leaked!?!? Joe Matt Chit-Chat 9 14-02-2004 21:14
Need Help With Windows Applications In C++ Hailfire Programming 9 05-01-2003 10:13
