Go to Post Our job as mentors isn't to teach them how to make a robot...It's to teach them that there is value in technology and being among the people who create it. - Andy A. [more]
Unread 10-08-2008, 22:06
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
SSH on VB6
This is not robotics related, but there are a lot of helpful programmers here so I thought i can ask.
I am trying to make a GUI interface for a system that is controlled via command line over SSH.
if it was telnet, it would have been no problem with winsock, but I cant find an SSH activeX or some code to do the encryption.
I rather not code the SSH encryption myself so it would be great. if anyone can help me to find some ActiveX component, or some code to do that.
Thanks in advanced!!
-Borna Emami
Team 0x27
Unread 10-08-2008, 23:56
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: SSH on VB6
No VB advice here, but PuTTY has a command line interface that you could use to execute commands over SSH. If you place the code to be executed in a shell script on the remote server, you could execute it in one line.
There might even be a dll interface based on putty, try googling...
Unread 11-08-2008, 14:16
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: SSH on VB6
SSH can forward ports. So I'd recommend using PuTTY and tunneling. Connect to it (which is on localhost) and it'll be forwarded to the server.
http://www.cs.uu.nl/technical/servic...y/puttyfw.html
Then you can run your own application on the server and a client and use PuTTY to assist with the connection. For instance, I'm forwarding port 139 from a local loopback device to my samba server and then I connect to it with windows. =) Much better than exposing 139 to the world.
If this sounds like something you might want to try, and you're confused. Just PM me.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 24-08-2008, 13:23
dpeterson3 dpeterson3 is offline
FRC #1178 (DURT)
dpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the rough
Re: SSH on VB6
I doubt you will find anything. SSH is a linux server and VB is designed for windows. You might be able to connect to Samba from VB. You might want to check out a project called CYGWIN on
http://sourceforge.net
Just put it in the search bar and you will get around 100 hits. The origional goal of the projec twas to create a SSH command line enviroment for Windows. You might look at their source code to see how they did it. I think it is in C, though.
Unread 24-08-2008, 17:35
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
Re: SSH on VB6
sorry but you are wrong. SSH is a protocol not a server. Also your comment about cygwin is off as well, it "is a collection of tools originally developed by Cygnus Solutions to provide in Microsoft Windows a command line and programming interface familiar to Unix users" ssh would be just one of the many commands and is not a really core feature. Putty and others do that much simpler and smaller.
Now to anwser the OP question, there are many options out there here is one that is not free but there is a trial version of:
http://www.ssh-activex.com/
and
http://3sp.com/en/maverick-net/
and
http://www.eldos.com/sbb/activex-ssh.php
and
http://www.jscape.com/sshfactorydotnet/
and a free .NET port for c# that you could modify to VB without too much trouble.... But then one my ask why are you using a language like VB to start with....
http://www.tamirgal.com/home/dev.aspx?Item=sharpSsh
A2D Solving the Imaginary Error Function...
Unread 24-08-2008, 19:27
FRC #1178 (DURT)
Re: SSH on VB6
Sorry for the mistake. I read somewhere that cygwin was designed to communicate via SSH. I guess I wasn't clear on the server part. I know it is a protocal. I was trying to say that SSH is usually a server protocal. I was refering to servers using the SSH protocal. Thanks for correcting me.
vb6/xp question Tom Bottiglieri Programming 5 04-07-2004 13:55
VB6: Joystick help! Astronouth7303 Programming 0 15-06-2004 17:05
VB6 Question PaPPy Programming 6 27-05-2004 11:54
