Re: 2009 Distribution Block
From my understanding the new distribution block is being fabricated by Diversified Systems (DivSys) out of Indianapolis. These are the same folks who provided the IR boards last season.
I have firm reason to believe these will be the best power distribution blocks since the 2005 season.
I totally get what you're saying, but that isn't saying much, given that IFI boards were great, and the distro blocks the last 2 years sucked.
This one uses screws to clamp down the leads... the same method the Rock-fail-well Distro' block used Those screws always came loose.We shall see... At least its nice and compact and not too heavy-looking.. |
The main battery leads are ring crimped and attached to a pair of press fit shanks. A nut is then tightened down on top of this. This is similar to the old IFI breaker board and the 120A main breaker connection, but with enhanced awesome. These are the square chunks of metal on the right hand side of http://first.wpi.edu/Images/CMS/Firs...ax_600x406.jpg As for the fanout past the breakers, these use Wago 745-85X and 745-83X cage clamp style connectors. A piece of spring steel, not a screw, supplies the clamping force. These are the blue and white connectors on the top and bottom of http://first.wpi.edu/Images/CMS/Firs...ax_600x406.jpg Last edited by EricVanWyk : 11-08-2008 at 19:22. Reason: Linked to the picture. |
#7
I like the New Control System, the 07-08 was really annoying.
#8
I for one enjoy using products that work--something IFI is very good at. FIRST has a dismal track record when it comes to introducing new vendors/products into FRC. It's going to take a lot more than fancy specs to make the new controller superior to the old--first it has to work, which is no small task. |
#9
For one, on the distro block the terminals were very hard to work with. They would wiggle out. There were other small things that i do like about the new controller. The new distro block has everything included into a package. BTW, Cory what terminal connectors did you use one your batteries, they were really cool.
#10
As for our batteries, we just used standard ring terminals. We had 4 gauge monster wire, which was what looked different from most teams. |
#11
Please note that the Rockwell block has a specification for strip length that teams chose to ignore. Without stripping to 5/8", the wire was guaranteed to push out as the screws were tightened. The new Waco blocks have a similar specification. You must strip 1/2" of insulation for the wire to be properly terminated in the 745-85X block according to the manufacturer. You must strip 1/3" of insulation for the wire to be properly terminated in the 745-38X block according to the manufacturer. Their ability to stand up to robot movement will be tested during the beta testing. Please standby...
We might as well get this discussion going early, so let everyone know what the spec is. |
#13
Well said Al. We never had a single failure withe the Rockwell. Properly used they were very reliable.
Any product improperly used is subject to failure. |
#14
EDIT: Thanks Al. Last edited by artdutra04 : 12-08-2008 at 15:20. |
#15
I am guessing you are asking about the new PD panel. I believe the intent is to ship with a nut designed for the power studs. (I don't have time to go look up the spec sheet, but I think they are metric) As I remember, that nut has built in anti-back thread so that it won't come loose. In any installation, some method of locking the turning device is recommended. Also, plan on securing the wiring so that it won't be distrubed when changing batteries. |
| pic: 2009 Distribution Block | Billfred | FRC Control System | 16 | 22-04-2008 17:16 |
| distribution block | Magnechu | Electrical | 11 | 14-02-2008 19:07 |
| Distribution Block | Magnechu | Electrical | 3 | 04-02-2008 21:38 |
| Stinger Fuse Block and Power Distribution Block | Don Wright | Electrical | 2 | 30-03-2004 10:45 |
| Anyone knowwhere to buy maxi block distribution block? | BrianB | Kit & Additional Hardware | 0 | 23-01-2003 12:46 |
