Go to Post it would be a sign you do too much robotics when you find toolpaths sexy. - Aren_Hill [more]
Unread 11-08-2008, 17:35
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
pic: 6WD Riveted Frame Development
Unread 11-08-2008, 17:54
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: pic: 6WD Riveted Frame Development
As long as you use enough of them, rivets work just fine for holding frames together, especially since you also have the top and bottom gusset plates. For some of the more high strength areas, you may want to stick with 3/16" steel rivets (such as where the front/rear frame members intersect with the longitudinal drive train members), but for things like the top and bottom gusset plates, 1/8" steel rivets work just fine.
Unless you need something to be removable, use rivets if at all possible. It makes it so much easier when you don't have to figure out how to get a wrench into the chassis to tighten nuts. ;-)
Otherwise, this definitely looks like a good chassis and drive train design so far.
Art Dutra IV
世上无难事,只怕有心人.
Unread 11-08-2008, 18:31
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
Now I do have one question.
Is that U-channel or Rectangle Tubing where the wheels are mounted? Now someone with more experience with cantilevered wheels correct me, but don't you need a place for 2 bearings to support the axle? If it is indeed tubing then never mind.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 11-08-2008, 18:57
Billfred's Avatar
Billfred Billfred is offline
1618 did rivets in the frame this year, 1/4" aluminum ones to match the kitbot. We ran them rivet-for-bolt, 72 in all, and had zero problems in testing and spirited running at Chesapeake. We had bumpers on three sides (the rear bumper was dropped after we realized how much of a pain in the butt it was to attach when we were already compliant), which seems to help by all indications.
Last year, we used 3/16" rivets to hold together the two members of our arm's tower. We used two on each side--you can see them on one side here, just beside the radio antenna. Even with questionable mounting of our tower, particularly in the rear, the rivets held together fine through all of Palmetto and our off-season demonstrations. The rivets sheared on one side following a particularly nasty tip at Brunswick Eruption and would've been easily fixed had I not left the team's rivet tool 700 miles away in South Carolina. (oops.) At that point, we just enlarged one hole to 1/4", stuck in a kitbot nut/bolt, and ran off to the next match.
Just two points of data--your mileage may vary, but I will note that rivets are the win.
Unread 11-08-2008, 19:52
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Team Pink this year riveted their whole frame together, we are planning to rivet the frame and then weld. Ask why?
This frame here:
http://www.chiefdelphi.com/media/img...4fa048a3_l.jpg
If you rivet the whole frame together with 90 degree angled aluminum. We took about three weeks to weld this whole thing. If you rivet it first, the welding is a lot easier for our welders. Meaning that you can have a frame welded in about 4 days.
R.C.
MadTown Robotics Team 1323
Unread 11-08-2008, 21:41
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
From this picture it looks to me like they are cantilevered, which worries me. Also it looks like the wheels are height adjustable in some way, I would love to have a closer look at how you are approaching it. Hopefully there is more support on those cantilevered then it looks, but overall it should be a solid frame that can take the beating your drivers will certainly put it through.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 12-08-2008, 00:17
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
1726 did a riveted chassis this year, made from 1 x 4 x 1/4" pultruded fiberglass channel, and .060" sheet 3003 aluminum for the full belly pan and top gussets. We used 3/16" rivets from the hardware store. It worked just fine. Also we used cantilevered axles, mounted directly to the fiberglass, and had no problem with them. There was quite a bit of design work in this chassis, so fabrication and assembly was straightforward.
The cantilevered axles worked because they were mounted with flange nuts with a 1" diameter bearing surface, and the fiberglass is thick enough that it would not flex or be damaged by the load. There were no lightening holes in any of it. Fiberglass is about half the density of aluminum, so the weight of 1/4" thick fiberglass is about the same as 1/8" thick aluminum of the same size.
I think there are some pictures on the NERDS photo gallery...
Unread 12-08-2008, 01:54
M. Mellott's Avatar
CAD God
AKA: Mike Mellott
The four main frame members are 1/8" thick aluminum U-channel, 3" x 1".
Originally Posted by Jonathan Norris View Post
From this picture it looks to me like they are cantilevered, which worries me. Also it looks like the wheels are height adjustable in some way, I would love to have a closer look at how you are approaching it. Hopefully there is more support on those cantilevered then it looks...
I'm hoping the additional views I posted better show/explain how the axles are supported:
http://www.chiefdelphi.com/media/photos/31782
http://www.chiefdelphi.com/media/photos/31783
The bearing block is the same for all six wheels. We intended on making several sets of blocks with the axle hole located at different heights, both with and without bearings. With this, we could conduct experiments with wheel height, demonstrating what happens when all six wheels are at the same height, or when the center wheel is lowered by a 1/16" or 1/8", etc. One frame, many options.
Thanks for the questions...
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 12-08-2008, 02:03
M. Mellott's Avatar
CAD God
AKA: Mike Mellott
I took a look at the pictures and noticed you notched the U-channel to insert the end into the end rail similar to this design. However, there appeared to be nothing joining the four fiberglass frame members together except for the bellypan and the four sheetmetal gusset plates on top of the four corners, with nothing actually inside the corners. Is that correct?
Unread 12-08-2008, 03:24
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Correct. It was plenty strong enough with just attachments on the top and bottom, any more brackets would have been unnecessary and too much work to put in. Thin aluminum channel may require more bracing if it's constructed in the same way, but the fiberglass is nice and stiff.
Unread 12-08-2008, 08:50
MrForbes's Avatar
AKA: Jim
In the design M. Mellott posted, it appears that the attachment at the web of the channel is probably not necessary, since most of the web between the wheel and the end of the frame has been cut away. Also the bending load is highest at the flange of the channel.
I'd suggest not cutting out the side frame members for lightening...leave them strong, and you should be able to eliminate the corner pieces that connect the webs of the channels, while enlarging the top and bottom gussets so that they make good-sized triangles.
Unread 12-08-2008, 15:32
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Our frames are typically assembled with a sort-of combination of press-fit construction held with rivets. In 2008, we inserted 1.5" square tube into channel with a 1.5" inside width; a tight fit. We then fixed it in place with four 1/4" rivets -- two on top and two below.
It holds very well.
Are you concerned about the torsional stiffness of the channel that contains the axle mounts? Rectangular tubing in the same application would be quite a bit stiffer.
--Madison--
...down at the Ozdust!
Unread 12-08-2008, 16:17
MrForbes's Avatar
AKA: Jim
The open channel seems to me to be easier to work with than tubing....and any twisting of the main side members could also be reduced by adding a lightweight channel crossmember across the middle of the chassis. This could be integrated into the structure that holds the electronics, or placed right next to the transmissions.
Unread 12-08-2008, 16:29
M. Mellott's Avatar
CAD God
AKA: Mike Mellott
You make a good point. I'm always concerned about the overall strength of the frame. I believe that the base frame is the foundation of the robot, and a team should never have to worry about it as far as maintenance--too many other things need attention and, barring a catastrophy, should be rock solid. We've always had solid frames, but often "solid" translated to "heavy".
I suppose we were trying to be a little different (as far as our past designs go), not only with the use of U-channel, but also the added weight savers. This is why we were hoping to develope the design over the summer, then construct and test/abuse during the fall once school starts up.
Unread 12-08-2008, 16:52
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
We have been doing a folded sheet metal riveted frame for 3 years now. While in general I really like it, this years game was particularly rough on it. The high-speed nature of overdrive combined with the less than compliant barrier wall made for some interesting bends in the frame this year. Our material is also a lot thinner as we use mostly 0.060 and 0.050 AL to make our frame.
If you do riveted joints, make sure that you check them periodically after major impacts and/or the end of the day. After a lot of wear and tear, then tend to loosen. Not that I would stop using them, but they do become a maintenance item. Also don't use the largest rivet that will package because having an up size option at competition is handy should they become loose.
pic: 1760 - 6WD with OMNI wheels Mark Pendergast Extra Discussion 1 20-03-2008 19:35
pic: Frame is falconmaster Extra Discussion 1 17-01-2008 23:11
pic: 6WD Design Iteration Madison Extra Discussion 7 01-01-2008 14:00
pic: 6WD Module Madison Technical Discussion 20 12-01-2007 10:09
pic: Isometric View of A 6WD module Cody Carey Extra Discussion 8 04-01-2007 17:19
