Go to Post Sometimes, having someone that can teach you just shows you another way to do what you've been doing, but in fewer moves. - Amanda Morrison [more]
Unread 12-08-2008, 16:00
run the trap!!!
Team Role: Human Player
Re: 2009 Distribution Block
Originally Posted by dlavery View Post
Although not necessarily a fan of the Rockwell distribution block because of its size, we had no complaints about its performance. We followed the manufacturers directions regarding wire prep. All inbound wires were secured with strain reliefs. We used wires of the appropriate gauge size, and left the ends loose (unsoldered). As a result, we never had a problem with wires working loose from the block during the entire season. We checked the clamp screws periodically to see if there was an issue, but found that they never worked loose and did not need to be retightened.
This is very good advice. Thank you. I'll remind the electrical people to actually read the manual next time
For the record, it never gave us any trouble either, but sometimes when we checked it we found that one of the wires was falling out
What method do teams use to secure the wires prior to entering the block?
-Philip J. Fry
pic: 2009 Distribution Block Billfred FRC Control System 16 22-04-2008 17:16
distribution block Magnechu Electrical 11 14-02-2008 19:07
Distribution Block Magnechu Electrical 3 04-02-2008 21:38
Stinger Fuse Block and Power Distribution Block Don Wright Electrical 2 30-03-2004 10:45
Anyone knowwhere to buy maxi block distribution block? BrianB Kit & Additional Hardware 0 23-01-2003 12:46
