Go to Post Now stop reading CD, do your homework, eat your peas, brush your teeth, and go to bed. Any time you spend speculating as to what Dave's ravings might mean is completely wasted. - Richard Wallace [more]
Unread 12-08-2008, 18:44
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Dewalt Shifting
Team 1718 just finished their first prototype of a "Dewalt" style transmission with a cim running into it.
We currently don't have a servo hooked up to it.
It is difficult to shift between gears one and two by hand - so much so that I doubt a servo could do it.
In addition, when we shift into "third" gear, the transmission freewheels. I haven't torn it apart and figured out why - I'm assuming the freewheeling is expected since we removed the last ring gear to mount the cim per the NBD whitepaper, however I am concerned over how stiff the shifting is.
Is this normal, or are there tricks to making it shift easily that aren't in the whitepaper? Or did we do something wrong....
Unread 12-08-2008, 18:49
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Dewalt Shifting
It sounds like you may have forgotten to remove some of the mechanisms inside that transmission housing that keep it locked into gear. There are springs around the housing that act a bit like detents and make it difficult to move the shifting ring.
If done correctly, you should be able to freely shift from 1st through 2nd and into 3rd without any change in resistance -- aside from waiting for teeth to engage.
Also, 3rd should not freewheel.
--Madison--
...down at the Ozdust!
Unread 12-08-2008, 18:53
Tom Line's Avatar
Re: Dewalt Shifting
Thanks! Now I know I need to get inside it and find out what's going on. It's probably all related back to the same issue.
I'll chase it down.
Unread 13-08-2008, 10:26
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
Re: Dewalt Shifting
http://www.chiefdelphi.com/forums/sh...ad.php?t=42461
Unread 13-08-2008, 14:12
Tom Line's Avatar
Re: Dewalt Shifting
Thanks Stephen, that's one of the first things I did before even reading your post - I didn't see the point of having the detent spring when the servo was handling position.
I have a feeling this has more to do with us taking apart the transmission repeatedly to learn how it works. We probably just put something back in wrong.
Easy Shifting for the Dewalt Transmissions? Ozeaden Technical Discussion 9 06-02-2008 18:37
Servo shifting a dewalt Stephi Rae Electrical 5 28-01-2008 12:30
Dewalt Shifting Questions Ben Piecuch Technical Discussion 3 20-02-2006 13:40
Shifting Efficiently Wetzel Motors 8 18-12-2004 11:42
Shifting Gears -- Anton Abaya Technical Discussion 26 22-01-2002 21:49
