Go to Post The culture has shifted, people. You can act shocked and complain, and likely lose the attention of the students you want to reach through FRC and other activities, or you can shift with it, and make FRC relatable and relevant to a bunch of good kids with foul mouths. - mrnoble [more]
Unread 12-08-2008, 19:32
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
Re: Posting LabView Code Easily?
Yup!
  1. Go to file File
  2. Hit "Print..."
  3. Hit "Next"
  4. Select "Icon, description, panel and diagram"
  5. Hit "Next "
  6. Select "HTML File"
  7. Hit "Next"
  8. Hit "Save..."
  9. Select a directory, this will create an html file and 3 images. Those images are what you want. =)
See example of what you get below.
*edits* Oh yeah, about sharing them out of attaching.. probably not. Unless you host them elsewhere and use image tags. But I think that's a bit harder than just attaching. Unless someone else has a better idea for that.
ID:	6779  Click image for larger version
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
LabView FRC Toolkit code level issue KHall National Instruments LabVIEW and Data Acquisition 2 11-06-2008 10:40
Any way to report errors in CD-Media easily without posting here? Elgin Clock CD Forum Support 0 20-04-2007 12:56
Configuring Labview code to easyC team877 LabView and Data Acquisition 6 16-01-2007 09:21
LabView Gear Tooth Sensor Code SkiRacer LabView and Data Acquisition 2 17-01-2006 03:53
Custom Dashboard code for LabVIEW ready for download. archiver 2001 3 24-06-2002 00:49
