Go to Post Your team will be more of a team and not a group of students who are just building a robot. Instead of being in FIRST, you will be FIRST. - JackN [more]
Unread 13-08-2008, 14:20
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Re: Posting LabView Code Easily?
One thing to think about *attention Brandon*... With all of these labview images going up.... server space?
Imagine if you took every code segment ever posted on CD and replaced it with a good 500k-1MB image... Perhaps there is some kind of vBulletin plugin that can be installed to allow image uploads of this type to be stored on a DIFFERENT server, as to not clog up the main CD server.
Also, I did a search already, it would be nice to upload your .vi file, and have the forum convert it to an image on-the-fly. This way, it would render the image file for when you need to view it, but it isn't being permanently stored. No such thing exists (as far as I can find), but maybe we have a few vBulletin coders?
Jacob
Unread 13-08-2008, 15:50
Unfortunately, several labview structures can't be flattened to a picture easily, like case statements. Any solution would have to make the vi available.
The printing to html does make separate images for each item in the case statement. However, by the time you look at several images, you might as well just open the vi.
Unread 13-08-2008, 16:40
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Exclamation Re: Posting LabView Code Easily?
I strongly disagree. Most computers can view jpegs but many fewer can view VIs. Opening a vi requires expensive, hard to set up software. Some sort of animated image format would be vastly superior and even a series of flat images are still viewable on mobile devices (like the one I am writing this post on).
I think a combination of the pictures and the vi makes of easiest for someone else to help you.
Unread 13-08-2008, 17:28
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
We've got more space than we know what to do with ... space isn't an issue.
Brandon Martus
e-mail
Unread 13-08-2008, 22:06
I'm not entirely sure if it is needed, but if someone responsible for the forum is interested in a tool to serve up images, that wouldn't be too hard as long as you can run LV on the server machine and plug it into a CGI. Get in touch.
Greg McKaskle
Unread 14-08-2008, 02:01
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
What d'you know, someone already mentioned this at NI communities (I didn't know until just now).
http://decibel.ni.com/content/message/1721#1721
-- Marshal Horn
Unread 14-08-2008, 08:17
I guess I've been on the receiving end of way too many movies watching someone write a diagram trying to demonstrate a bug. True, it has its uses, but most times, I ended up panning to the end, looking at a super grainy frame, and spotting the problem. So, the time to make the movie, time and space of the movie downloads, and time I spend watching their movie so I can make their diagram on my machine for experimenting, are all time I wish I had back.
But, the forty-seven second demo watching someone type into a text field almost convinced me I was wrong.
In other words, simplifying a VI to show the problem so that you can post a good succinct stand alone snippet of code that others can run, modify, learn from, and send back in an improved form, is my preferred way of discussing LV or C code. Screenshots are a good way to identify areas within the code and are sometimes enough. A movie has potential, but most of us don't have enough Spielberg in us to pull it off.
Greg McKaskle
Unread 25-11-2009, 12:32
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Revisiting this thread...
Is anyone excited to be able to use the LV 2009 Snippet feature in FRC 2011?
-- Marshal Horn
Unread 25-11-2009, 12:58
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
I would be, but in the Senior Mentor Conf Call last week, they said we are getting LV 8.6, not LV 2009
I'm hoping they were wrong....
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 25-11-2009, 13:03
That's why he said 2011, not 2010...
Here's more info on the snippets
Unread 25-11-2009, 13:12
Jeff Pahl's Avatar
I'm hoping by 2011 they will have moved us to LV 2010, which will be released at NI Week 2010, sometime around August 2010. NI has announced they are moving to a yearly major release schedule, tied to NI Week. At least that's what they stood up and said in front of a couple hundred of us at the NI Symposium I recently attended...
It would be nice to be working with the current version we are using in industry, instead of trying to remember which things you are used to that you can't do in the FRC version
And yes, I did have a mental lapse on the dates for next year... after 3 days of staring at the spreadsheet I'm working on, all numbers are starting to look the same
Unread 25-11-2009, 16:49
I saw somewhere that they started prepping for the 2010 season months before LV 2009 was released. Maybe in the future they can improve the time of the development cycle.
What we with FIRST get is much newer then I get at work.
Unread 25-11-2009, 13:08
Ask again in a year or so? LabVIEW for FRC 2010 is basically LV 8.6, so far as we know.
Unread 14-08-2008, 14:24
AKA: Jacob Komar
I really like this software. I just downloaded it, and installed it, and used it. It's beautiful and serves the purpose.
Thanks!
-Jacob
LabView FRC Toolkit code level issue KHall National Instruments LabVIEW and Data Acquisition 2 11-06-2008 10:40
Any way to report errors in CD-Media easily without posting here? Elgin Clock CD Forum Support 0 20-04-2007 12:56
Configuring Labview code to easyC team877 LabView and Data Acquisition 6 16-01-2007 09:21
LabView Gear Tooth Sensor Code SkiRacer LabView and Data Acquisition 2 17-01-2006 03:53
Custom Dashboard code for LabVIEW ready for download. archiver 2001 3 24-06-2002 00:49
