Go to Post I'll just be happy if they give us a great game. - Koko Ed [more]
Unread 13-08-2008, 14:23
peter_p peter_p is offline
FRC #2338
peter_p is an unknown quantity at this point
Crab drive question
If i put this in the wrong spot, sorry, im new to this forum, my team and i are trying to put together a crab drive in the off season and a just had a few questions:
How do we keep shaft bores and bevil gear holes are inline?
how do we make sure our sprockets are inline?
any help is appreciated
Unread 13-08-2008, 14:55
RaMoore's Avatar
RaMoore RaMoore is offline
AKA: Rachel Moore
FRC #3005 (RoboChargers)
RaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud ofRaMoore has much to be proud of
Re: Crab drive question
I think it would help me in understand your question if you could more specifically reference the parts your talking about. I have seen several implementations so maybe relate to a similar design picture.
I'm not an expert on crab drive by any means but I do have some experience with the 118 design. Similar to:
http://www.chiefdelphi.com/media/photos/31078
http://www.chiefdelphi.com/media/photos/28442
http://www.chiefdelphi.com/media/photos/28443
Rachel Moore
REV Robotics | www.revrobotics.com
Unread 13-08-2008, 15:01
FRC #2338
oh sorry. this is for putting together the wheel housing
i just wanted to know when fabricating the housing how to keep the wheel shaft bores even so we dont have crooked wheels and such,
how we drill the holes fro the bevil gears to they line up properly
and any tips for getting even drive sprockets
Unread 13-08-2008, 15:32
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Precision tools, and a skilled machinist. Crab drive should be done on at least a mill, and preferably a CNC one. Use CAD to create a detailed model of your design, and work from that.
Unread 13-08-2008, 15:42
RaMoore's Avatar
AKA: Rachel Moore
From a machining point of view you're best served with access lathe and mill (CNC probably needed for the nicer, lighter designs) while access to waterjet/laser cutter will make some of the machining much faster and simpler.
To get the all the gears and sprockets lined up and keep the keys in you just need to cut some bushing that are the right lengths to keep everything lined up.
From McMaster we use:
6391K215 1/2" ID Sleeve Bearings (custom cut these to length for vertical and upper horizontal shafts)
1570K43 1/2" Keyed Aluminum Shaft (for vertical and upper horizontal shafts)
5911K42 3/8" Aluminum Shaft (for lower, wheel, shaft)
Small PVC or sleeve bearing for the 3/8" shaft
The vertical shaft comes down through the middle of a turned piece guided by bearings at the top and the bottom which keeps the shaft lined up with the upper horizontal one. If you are transmitting power form the upper horizontal shaft to the wheel via #35 chain then that alignment isn't too critical, but the bevel gear spacing needs to be more carefully adjusted with the custom cut bushings.
Don't get discouraged, but crab drive is very resource and time intensive, lots of CAD work before you start cutting with reduce mistakes and simplify your design... There are 21 machined pieces, 8 bearings, plus shafts and spacers in each of our wheel boxes.
Rachel Moore
Unread 13-08-2008, 17:45
run the trap!!!
Team Role: Human Player
A really simple way to do this is to make the entire module out of boxed aluminum (like this). That way you will only have to drill one hole, and it will match up on both sides.
As for the miter gear; be careful. Make sure the two drive axles are directly over each other at right angles, and leave some room above the miter gear so you can position it up and down.
-Philip J. Fry
Unread 13-08-2008, 18:08
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Have you used those shafts in the past? The first is 2024, which is probably OK. The second is 6061, and I would almost guarantee that it will fail if used in such a high load application. Especially at 3/8" diameter. I'd recommend 2024, 7075, or 7068 for shaft applications. 2024 is the most commonly available (and cheapest).
2001-2004: Team 100
2006-Present: Team 254
Unread 13-08-2008, 20:38
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Agreed, on any applications that a shaft does not need to be welded to the frame or to something else, use aircraft grade.
R.C.
MadTown Robotics Team 1323
Unread 14-08-2008, 07:45
I think you will be unhappy with the performance of the bevel gears transmitting power. The design linked above with the motor in the crab module has worked for us when we use crab. It is easier to get wires into a turning assembly.
We always find ourselves reminding teams that they shouldn't dedicate themselves to a particular drive system this far in advance of the kickoff. We use crab drive if and only if the game needs it. There are tradeoffs for weight and programming that could be used for other devices.
Unread 14-08-2008, 12:29
RaMoore's Avatar
AKA: Rachel Moore
This was our first year to try crab and that is the shaft material we used, we didn't have any problems, but then again I wouldn't say the robot experienced any real competition level stresses... it's funny when all the mentors are EEs but the wiring turns out to be the problem.
It's really nice to be able to have different drives depending on the game, but newer teams or ones with limited resources should consider picking a drive and building it preseason as practice and staying with that frame and drive for a few years until they are more established. Switching drives to match the game can be very resource intensive, and it also seems that for most any game any drive system will allow teams to still score and not having the reinvent the drive means they can spend more time on other aspects like manipulator. (I wish someone had told me this when starting out...)
Rachel Moore
Unread 14-08-2008, 12:31
AdamHeard's Avatar
Lead Mentor
For that exact reason is why it is a bad idea to lock into a very resource intensive drivetrain preseason. They'd be better suited developing a 6 wheel or other simpler drive if that was their goal.
I agree with your overall sentiment, just not in the case of a crab drive.
Unread 14-08-2008, 12:44
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Don't be discouraged though - if your team wants to make a crab drive for an off-season project, DO IT! What better time to learn than now and not have the build season time constraints placed upon your team? Better to try it now and mess up than in January. After you've made a successful one you'll probably be able to make the next one in half the time and you'll have that experience under your belt already.
Our team plans to work on some practical yet fun off-season projects. It's a great way to give the new people some experience prior to build season.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 14-08-2008, 12:54
RaMoore's Avatar
AKA: Rachel Moore
Sorry I didn't mean that to specifically apply to crab, but more generally to the concept of always considering a change of your drive for the game. Crab is intensive and unless you can get one working preseason most teams shouldn't try it for competition. This is not to say don't try it, everyone will learn from this kind of project. "Stretch goals" right?
Although I don't know 2338's situation, sometimes challenging yourself can be a catalyst for your team. I'd say by most metrics that for us(1817) to do crab this past year would have been in the "bad use of resources" category, but the level of complexity and dedication required plus the "cool" factor has gotten us more mentors, money, and attention.
Rachel Moore
Unread 14-08-2008, 21:01
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
I'd say that designing/building/programming/utilizing a swerve drive in the off-season is a great way for students on any level team to work on their all around robotics skills. Get everyone involved, you can teach wayward freshmen the finer parts of manufacturing precision parts, your programmers get some new and very interesting "opportunities" (problems in disguise), and it is just a great way to build team work in general. Be sure to set deadlines though, our team (1625) tends to find as many reasons as possible to procrastinate when there are no actual deadlines set or impending on them. Once you have built said crab drive, be sure to never stop thinking of ways to improve it, make it lighter, more durable, more maintainable, anything to better it. Even if you don't wind up building one for next years game or it doesn't feasibly apply to the gameplay, your team will have walked away with invaluable machining experience and just experience in general in the ways of teamwork and comradery. Also be sure to have a few LAN parties to offset the idea that it's actually work (that's what we do).
Unread 15-08-2008, 00:57
Aren_Hill's Avatar
Build Nifty Things
I was quite happy with the performance of our bevel gears in our drivetrain, part of it is deciding whether to sacrifice the efficiency for the pro's of coaxial (no limits). Which i chose coaxial for the simple fact that no matter what the programmers shouldn't be able to break the drivetrain .
And the better you align them the more efficient they'll be, we had a 13fps high gear and if you watch matches with us in them we get moving pretty good, so the efficiency loss is not very noticeable.
A guy who likes robots.
Crab Drive RMS11 Robot Showcase 46 05-09-2008 22:34
Crab Drive nukelear1991 Programming 13 21-12-2007 18:02
Crab Drive Joe_Widen Technical Discussion 9 21-04-2006 21:50
Crab drive question Tazlikesrobots Technical Discussion 13 31-07-2005 20:51
Crab Drive Collin Fultz Technical Discussion 3 04-09-2002 16:35
