Re: Wiring help and connectors
As far as I know, there has been no official word on wire type. However, since we will be using the same voltage battery, same current breakers, and same (or similar) motors, I would imagine that there would be no need to change this.
Ok thanks, only reason i was asking because we're about to buy about three hundred bucks worth of high strand silicon wire. I really need the info about the battery connector or does anyone else have a good connector for the battery besides the kop ones.
If you mean the end that connects to the battery, just get some 6 gauge ring terminals from McMaster (7113K446). |
http://www.robotcombat.com/products/0C-PP175.html |
| Need help Programming and wiring camera! | Amisca | Programming | 1 | 14-02-2006 18:37 |
| need some help with the OI, and wiring a display | pryoplasm | Control System | 8 | 10-03-2004 20:46 |
| Slip connectors (custom electrical connectors) | Damian Manda | Electrical | 2 | 08-02-2003 17:53 |
| Diagrams for wiring of 15 and 25 pin connectors | archiver | 2000 | 2 | 23-06-2002 23:03 |
| RJ-45 connectors, DB25 connectors and the like: legal or no? | Andrew Wyatt | Technical Discussion | 6 | 04-01-2002 22:53 |
