Go to Post Please forgive any possible profound language. - PortugazD.Ace [more]
Unread 16-08-2008, 20:00
kajeevan kajeevan is offline
FRC #0188 (blizzard)
kajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud of
pic: 6w/d Chain base
Unread 16-08-2008, 20:03
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Re: pic: 6w/d Chain base
looks sweet! The only thing I might suggest is a support bar i the middle. You dont want for somebody to hit you from the direct side and the whole chassis compresses inward. You could move both supports in a bit to fix it also without adding weight.
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 16-08-2008, 20:45
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
The only thing is the weight. 44 lbs is a lot, even with gearboxes. The lighter the better:
faster
more weight for other things
R.C.
MadTown Robotics Team 1323
Unread 16-08-2008, 21:45
how thick is the 4x1 tubing? 1/8"?
Unread 16-08-2008, 22:28
R.C.'s Avatar
Also if you have access to a CNC or Waterjet, that would lose a lot of weight.
R.C.
Unread 16-08-2008, 23:02
Or just a mill if you have one. This would take a lot of time but it saves money and all the weight you want.
You could also do the same cheese holes with the cross braces.
Nice design though.
Unread 16-08-2008, 23:06
R.C.'s Avatar
Originally Posted by lilstogi11 View Post
Nice, but some teams own a cnc, so you may want to ask them. 1323 offers to help any team with machining if they need it.
R.C.
Unread 19-08-2008, 09:53
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
You could go with 3x1 tubing and angle aluminum for mounts to the transmissions. One angle aluminum piece on top of the 3x1 and one on the bottom, which should cover the 5" face of the transmission for mounting. The angle aluminum could be attached to the 3x1 via welding or via riveting.
Weight savings should be roughly 4.5 lbs assuming a 36"x27" base. Since that's 4.5 lbs of pure aluminum, it'd wind up being less expensive as well.
GitHub
Unread 19-08-2008, 16:41
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Why not look into using plate and standoffs to save even more weight. You only lose a little bit of strength but it is easier to work on the drivetrain and much lighter. For an idea of what Im talking about take a look at this frame that we are working on :
http://www.chiefdelphi.com/media/photos/31759
Mentor 2415
Unread 19-08-2008, 22:54
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
With your choice of using inner and outer frame rails to support your wheels, plus your use of standoffs (or what appear to be standoffs) between the frame members to protect the wheels in case of a side hit, you could use 4" x1" U-channel in place of the box tubing--that would save a lot of weight. Adding cross members (at least 1, probably 2), as suggested by RMS11, would be a good addition...and you could get away with using 1/16" wall on the cross members.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
pic: Base Idea kajeevan Extra Discussion 10 27-07-2008 16:56
Circle base vs. Rectangle base Pelicano234 Technical Discussion 13 15-01-2008 16:49
pic: "Driveable Base" Cody Carey Extra Discussion 6 27-01-2007 23:29
pic: 1024 Base Michael Long Robot Showcase 4 17-02-2006 08:53
Chain and chain breaker source? kmcclary Off-Season Events 4 22-10-2001 22:51
