Go to Post Warning: You have entered an it's-so-crazy-that-it-might-just-work zone - Natchez [more]
  #44   Spotlight this post!
Unread 16-08-2008, 21:15
Re: Compact rio not being able to use C
Originally Posted by slavik262 View Post
I realize the base code will compile in C++ if you can compile in C. However, I'm looking forward to using the features presented in C++ that aren't in C such as being able to use Object-Oriented Programming techniques and templates. My question is: will we be able to write/compile code in C++? I thought that this was the case.
Some of the cutting edge C++ stuff may be a bit rough, but the LabVIEW code base contains plenty of C++, and it runs there. As usual, bringing in arbitrary C++ code can run into rough spots when deciding whose STL implementation to use, or doing lots static initializer stuff, etc. But the short answer is, that it is a C and C++ platform via Wind River tools, and a LabVIEW platform via NI tools.
Greg McKaskle
First CROSSING not being scored? jgannon Rules/Strategy 22 09-03-2008 11:08
CMUCam Forum messages are not being poseted as recent activity in the portal Bob22341 CD Forum Support 3 31-01-2007 22:34
Ethics 101: To re-use or not to re-use? aaeamdar General Forum 87 07-12-2006 19:10
Anyone concerned about the possibility of not being allowed to go to Nationals? skrussel Championship Event 41 03-04-2003 11:35
EDU RC not being recognized... Caleb Fulton Programming 5 24-03-2003 09:29
