Go to Post I would like to think that I would be considered smart no matter who I was. - Kelly [more]
Unread 17-08-2008, 21:21
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: 5 Inch Wheel
1323 would machine it out for you if you guys needed, just email me. We machine out parts for teams in need.
R.C.
MadTown Robotics Team 1323
Unread 17-08-2008, 21:25
Triple B Triple B is offline
all hail Passmore
AKA: Mike D is FTG too
None #0233 (The Pink Team)
Triple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant futureTriple B has a brilliant future
unless you would have to chew the shafts with your teeth, it will be worth it compared to keyways, also its a very basic machining practice with a reletivly loose tolerance if you needed to pay someone to machine them for you.
mike d
See Ya
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Thanks, are you in atlanta? We have a source in atlanta but it is just hard to get there and back in traffic, plus if something happens we cant fix it spur of the moment.
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 17-08-2008, 21:26
R.C.'s Avatar
No, California.
R.C.
Unread 17-08-2008, 21:30
all hail Passmore
i would think there would be plenty of shops around atlanta that would be able to do it, if not, I am in florida, send me some dimensions and i will whip them out for you.
mike d
See Ya
Unread 17-08-2008, 21:56
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
nvm (how come I can't delete this post?)
Unread 17-08-2008, 22:21
run the trap!!!
Team Role: Human Player
Ya thats our problem, we have a mill but no lathe. We could do it, but it is a huge hassle and we wouldnt have the freedom of doing this in shop... Hopefully we will get one sometime...
Well, you could always do it the opposite way. Machine hex shafts out of round-stock, and then use the AM hex hubs.
We did this with our mill and a dividing head. We never bought any broaches or hex shafts. Just used the parts from AM and metal bars laying around my barn.
It depends on the design.
-Philip J. Fry
Unread 18-08-2008, 02:27
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
While it's true you can't really make a very good keyway on a mill, you may be able to make a hex or D-shaft bore on the mill. 1/8" end mills are available up to about 3/4" in length, so you should be able to mill a hex shaft bore out of the block.
And, now you're all about to type 'what about the rounds on the corners from the round cutter?'. Well, personally, whenever things really need to be square I do one of two things: 1, before the milling operation, drill holes at all of the points the fillet would be left from the end mill, thus removing this excess material. Or 2, If you want to be trickier and more efficient, program over-travels the length of your tool's radius away from the center of the bore you're making, also eliminating the corner radius. With a hex shaft, you should still have plenty of surface area left on all of the sides of the shaft... you should only lose 1/8" of each side.
If you're mass producing these, you can always cut your bore times by starting with a larger tool and only finishing the corners with the 1/8" tool.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 18-08-2008, 03:36
run the trap!!!
You could also drill a 1/8" hole first (offset it the right amount from center) and then bore the center hole. Lot easier than using end-mills!
-Philip J. Fry
Unread 18-08-2008, 23:55
NickE's Avatar
NickE NickE is offline
_
A much easier solution than milling out a hex is to broach it. Mcmaster sells hex and square broaches in a variety of sizes.
http://www.mcmaster.com/#catalog/114/2462
At $128 for a 3/8" hex broach, they're not cheap. However, they will certainly save time over milling out a hex. Also, your hex come out without rounded corners.
4 inch wheels R.C. Technical Discussion 13 12-06-2008 17:58
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
Going over 6 inch step with 12 inch wheels Joe P Technical Discussion 25 12-04-2004 11:15
12 Inch Wheel Available in Several Formats Ed Sparks Inventor 1 19-01-2004 07:12
pic: 6 and 12 inch platform rise CD47-Bot Extra Discussion 2 18-01-2004 09:15
