Re: Variable rollover with Labview (suggestions?)
There are many ways of doing this.
I'd start along Eric's lines of asking more questions. The easiest way to detect overflow is before the operation that causes it. Before adding or subtracting the delta, determine if dX is greater than the boundary it is approaching. If so, do some wrapping code. Key operators that may be handy are the "Integer Division", which performs the modulus operation, giving IQ and R. There is also the "In Range and Coerce" node. Have fun. Greg McKaskle |
| Problems with CMUcam & LABView | Daniel_H | LabView and Data Acquisition | 1 | 30-01-2006 12:07 |
| Problem with freezing frames in LabVIEW | pdc | LabView and Data Acquisition | 2 | 26-01-2006 01:34 |
| Problems tracking with CMUCam2 in LabVIEW | PhilBot | LabView and Data Acquisition | 5 | 17-01-2006 20:42 |
| Need help with 255 Variable | Joseph F | Programming | 18 | 26-02-2002 14:49 |
