Go to Post you might want to consider the Edu-Robo-Whatevertheheckitscalled RC - Matt Krass [more]
Unread 22-08-2008, 02:12
Protronie's Avatar
Protronie Protronie is offline
Have big wrench...and will use it!
Protronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud ofProtronie has much to be proud of
Send a message via ICQ to Protronie Send a message via Yahoo to Protronie
Re: How to clean a Victor?
Yeah man, stay away from the compressed air... not only are you driving stuff deeper. If your using a standard shop air compressor set up, your tossing oil & water all over everything.
Shop vac the better way to go, I always use a small soft paint brush to help loosen anything chips that might be bothersome about being sucked up.
Don't forget your PPE's when doing it and be sure the robot is powered down.
-p
Protronie rule 5 - When the big wrench starts swinging, get out of the way!
Unread 22-08-2008, 02:57
BT987's Avatar
BT987 BT987 is offline
FRC #0987 (High Rollers)
Team Role: Human Player
BT987 has a spectacular aura aboutBT987 has a spectacular aura about
yeah and if you use the small can of air dont turn it upside down you will freeze it lol
-2009 Las Vegas Champions(1622 and 1013)
-2009 Las Vegas Chairmans winner.
-2008 IRI Champs(330,67,68)
-2008 Arch. finalists
-2008 Vegas winners(39 an 1013)
-2008 Vegas chairmans winners
-2007 World Champions! thanks to 190 and 177
-2007 Vegas Finalist
http://www.team987.com/
pic: Clean Field! Joe Matt Extra Discussion 6 19-03-2006 00:00
Victor 884's not behaving the same as Victor 883's programmer1 Programming 13 10-03-2004 21:51
