Go to Post Watch out, guys, Lisa's coming.... worse than any hurricane or tornado you can imagine! - KathieK [more]
Unread 22-08-2008, 08:14
Re: Treads, Tracks, Tank system Talk/Help
Some of the issues you are asking about are typical of tank tread systems. One that you have not mentioned is the bane of tank drive using treads or locked wheels, i.e.stalled motors.
When using treads on carpet, the side friction (during turns) with the carpet is so high that robot has to hop to break free from the carpet surface. Since the motor/transmission is usually capable of enough torque to overcome the friction, the robot hops when turning. However, during these moves the motors are at, or very near, stall. In a four motor drive using the CIMs, that is potentially over 400 amps. In the IFI control system, this causes the battery voltage to temporarily fall below the drop out voltage of 8 volts, and the controller goes into protect mode disabling all outputs and switching to the backup battery. (We don't have any data yet on what the new controllers might do under these conditions.) A wheeled robot in the same kind of drive could have a little less side friction but the problem remains and they also will hop to some extent in turns. Drivers can minimize the hopping by turning in conjunction with forward or backward motion. The AndyMark style wheels that have no side friction were developed for this reason. Everyone tries tank treads from time to time, but the tradeoffs are usually significant enough that teams go back to wheeled drive systems. Any game in which turning is required will have a minimum number of robots with treads. This year's game is a good example.
Tank Treads??? SLA Kit & Additional Hardware 2 16-01-2007 20:53
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
Tank treads snowdragon General Forum 0 21-01-2004 16:57
Tank tracks vs. Wheels MBosompra Technical Discussion 28 16-01-2004 23:31
Where Can I Get Some Wheels Or Tank Tracks? Alex Cormier Kit & Additional Hardware 5 13-01-2003 22:58
