Go to Post Read the rules. And then read the rules again. Then, get together as a group and read the rules together. - Knufire [more]
Unread 22-08-2008, 19:02
UndergroundVoid's Avatar
UndergroundVoid UndergroundVoid is offline
System Ready...
AKA: Lynx
UndergroundVoid is a jewel in the roughUndergroundVoid is a jewel in the roughUndergroundVoid is a jewel in the roughUndergroundVoid is a jewel in the rough
Send a message via AIM to UndergroundVoid
Re: Treads, Tracks, Tank system Talk/Help
Nicely put EricH.
I refuse to go silently into the night by taking the easy way out.
The manual doesn't have all the answers since nobody can plan for everything.
Things can be more simple than you think.
Unread 22-08-2008, 21:24
Originally Posted by UndergroundVoid View Post
I personally choose the tank system for its ability to have the power to climb over any planed or unplanned obstacles. Tracks provided a larger footprint to the floor allowing for greater traction that no other dive can compare with equivalent materials (such at same gear ratio and tread material). Tracks due to their larger footprint can be harder to push around and with the right gear setup push others that may be friend or foe.
Power depends on the motors and any mechanical losses in the drive system. All else being equal, wheels and tank treads should have no significant difference in pushing or climbing power. Tanks are better at dealing with unstable surfaces, but unless what you're driving on moves or shifts there probably isn't a good reason to use them.
A larger footprint does not have any theoretical advantage in traction. With the same coefficent of friction and the same weight, the amount of surface contact is not a factor.
With carpet deforming more under the concentrated weight of wheels, the actual traction of a FRC robot is somewhat complicated to predict in advance. Experiments seem to show that wider wheels are better in practice than narrower ones, but long tank treads don't give the benefit you attribute to them. On the contrary, the difficulty they create in turning is usually considered to be a good reason to avoid them.
Unread 23-08-2008, 10:49
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
This is sort of true. With compliant surfaces like carpet, rubber tires and treads there is some degree of mechanical interlock that can change the grip level to normal load.
While you can generally equate a coefficient of friction as a constant, there are noticeable changes relative to load. I think 494 did a neat project on this.
%slip also makes a huge difference.
Any students interested in a good/simple science fair project, this is a solid one. Map the coefficient of friction between two materials (let's say carpet and brown ruff belting) vs. contact area and load. You will get a really cool 3D curve and likely win some scholarship money (and might even learn something) in the process.
Unread 23-08-2008, 11:39
run the trap!!!
Team Role: Human Player
Originally Posted by Gdeaver View Post
Thinking about tank treads and other drive configurations is probably a good idea. The past few years many teams have gone to 6 small wheel designs. For the most part the games have been played on flat surfaces. This has not always been true. What would your team do for a drive system if this years game required going up stairs or getting up on a platform?
Has there been a game yet that REQUIRED teams to climb obstacles? Seems a lot of the successful teams from 1999 and 2004 found clever ways to avoid climbing things.
-Philip J. Fry
Unread 23-08-2008, 14:50
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
There have been games with obstacles that needed to be climbed. But I understand what your saying.
But treads, WHEN DONE RIGHT, are a great option for maneuvering up and over obstacles such as steps, ramps, etc...
There is a reason why tanks use treads.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 23-08-2008, 15:04
AndyB's Avatar
AKA: Andy Burchardt
The Question:
1. What gear ratios should i have for the tank tank system (motor to gearbox output)?
Note: I'm not stupid i know there is a series of equations to find the right ratio but I'm looking mainly for what others have done that might work for me.
2. How to solve the walking effect where i seen some robots with treads hobble as they turn and even become unbalanced that the driver has to stop?
I assume this is from the tracks not being held center because of certain belt track systems.
3. How to correctly tension the tank system, such as spring loaded or motor controller tension or to have the tracks at a fixed tension set by the frame?
General Talk:
I'm also looking for just a general what you may have done in this field of drive train and certain things you may have experienced that may help me and everyone have a better idea on how to produce tank systems to please the tank gods.
Now to get back on subject. His question wasn't "Should I do treads?", but "How can I best do treads?".
1. I can would agree with some other posts in this thread that 2-speed is a great way to go as far as treads go. A lower gear for turning, pushing, and getting over obstacles and a higher gear for everything else. I would recommend something like a 15:1 for low gear and a 10:1 high gear but this is really something you have to play around with. I don't know what your target range is. The low gear is the most important to figure out, as the high gear is really just what you want your speed to sit at. You have to make sure with your low gear to not get screwy with the amperage.
2. The walking effect as others have mentioned is from the treads overcoming the enormous amounts of friction. A great way around this is decreasing your floor contact. Look at the picture of 522 i posted earlier.
3. From experience, I know you do want to go with some sort of tensioning system. Look at the way many teams tension chain. Many of the techniques can be replicated with belting. You want to make sure to get a good wrap on your drive pulley(s). So keep that in mind as well.
The one thing you need to realize is that More Tension = More Current Draw. Less Tension = More Slippage. You need to find a good spot.
As far as general experience goes, when I was on 269, we tried treads in 2006. We made the mistake of using friction belts instead of timing belts. Needless to say, we failed miserably and stripped out the whole drive at our second regional and replaced it with 2 wheels.
Unread 23-08-2008, 15:44
Dick Linn's Avatar
no team (Synergy)
I see tank treads as having two advantages. One is in the real world where you have heavy vehicles on very soft and irregular ground. They do help reduce the ground pressure, as is beneficial for tanks and agricultural tractors. The other is in climbing over irregularly shaped objects, as there is a piece of tread that can catch whatever traction surface is available and not leave you "high-centered". The downside comes on a somewhat regular and relatively high traction playing surface where you have to contend with turning and keeping the tread on.
My personal experience only extends to 4 wheel drive using fairly large, pneumatic tires (Skyway). Those things had more than enough traction to make turning difficult, despite a very short wheelbase. In one regional competition shoving match, we and the opponent both flipped over backward as a result of a standoff pushing match. Neither robot moved more than a couple of inches one way or the other.
In terms of "best doing treads", what are peoples opinions on the number of drive and bogey wheels, and methods of tensioning?
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 23-08-2008, 17:12
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Before you start, really do consider tires if this is for a FIRST robot. We used tracks in '04 and '06, and found tires to be far superior ('08). 6WD or a 6x4 have proven to be great drive trains.
For us, a sliding/clamping tensioner proved very effective. Our favorite and lightest tensioning scheme was on our '06 robot. The last wheel mount point was on a seperate piece of aluminum which has a slot milled out of both of it's sides which slid in and out of a groove milled into the main part of the frame rail. So, to tension, you just took something like a screwdriver and pried the tensioner away from the frame rail hard as you could, then tightened two bolts that clamped down the tensioner (the two sides of the tuning-fork-like cutout in the end of the man frame rail). As a note, the only problem with our '06 robot's track system was in the design of it's bearings: the design of the bearing mounts had too loose of tolerances, which allowed the end sprockets to deflect slightly, allowing the track to work itself off if hit from the correct angle while doing a turn. As a redesign, simply taking more time to make each bearing pack would have eliminated this problem.
We used BrecoFlex both in '06 and '04 on custom FDM sprockets.
-q
p.s. If anyone wants a picture of the tensioner clamp system, just let me know and I'll see if I can dig up one or two to post.
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 23-08-2008, 18:03
Dick Linn's Avatar
no team (Synergy)
"...really do consider tires..."
I agree. If we were competing on a course of loose gravel or shale, I'd seriously consider tank treads. Otherwise, I think it is overkill. Do not confuse cool-looking with effective. As they say, "Run what you brung". The results will tell...
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 23-08-2008, 20:42
AdamHeard's Avatar
Lead Mentor
In the context of FIRST, the only real advantage treads has is in climbing obstacles/uneven terrain.
I also believe that in every game so far, there were much simple ways to traverse the obstacles than treads. It'd take some really rough/odd obstacles to get me to advise my team to use treads.
Unread 23-08-2008, 21:53
Joining the 900 Meme Team
FRC #0079
Yes, the reason is that they are better at spreading the weight of an 80 ton battle tank when crossing mud.
I won't advise you how to do tank treads because I don't know how, but I will advise you to look to the military and their move away from treads. (run a search on Stryker) Tank treads are great for uneven and shifting terrains but for speed and maneuverability they are not the most effective.
Now, would it be cool to do a tank tread system that could climb a 70 degree incline as a demo? Oh you bet it would be. My best suggestion would be to look at the military tanks and how they work. An interesting thing to do might be to have a way of letting your treads lose friction as they are moving sideways (similar to omni wheels) Might be interesting to make work, dont know how useful it would be though.
Just my (programmer's) $.02
Unread 24-08-2008, 16:33
System Ready...
AKA: Lynx
I started this thread to help myself and other to improve and create ideas about track systems. Though it seems most here are rather happy to bury them in the ground and call it a night. I admit that a track system may not be the best drive system or easiest to build but that doesn't mean that they wouldn't be as effective to a game as any other drive system. It truly depends on how you build you machines and how you operate it.
To step back to the main part of my project folder which i didn't want to do . Here is the true purpose:
To create a universal framework that can be use for the most of the FIRST drive trains and to be suitable to the challenge.
So in my work I'm at the final part of this which is adapting it to a tank type since the wheeled versions are completed. Though since for track systems i only know a few minor things about I figured I might ask around to team who have tried them to get a better idea. I really don't want to talk about my projects since i filled in the gaps to this point and wanted to keep the thread focused on what i didn't know and what could be done for track systems. The funny thing is i didn't expect it to get unfocused and try to push me away from a track system.
Unread 24-08-2008, 18:02
Mr.Rush Mr.Rush is offline
AKA: Braden Rush
FRC #0401
Mr.Rush is on a distinguished road
Image from back in the day
I'm not sure if I can be much help to the cause but our team ran tank track back in the day, though now we are know by those who visit our pit for drum wheels.
Recently two of us attempted to resurrect this robot and learned a little about how the treads worked. It was tensioned with a worm gear, and before the old gear boxes gave way seemed to maneuver fairly well with the tension on the looser side of tight. It wreaked havoc on the breakers though you could year them popping clear across the shop when the tension was too great and it tried to draw more current.
Unread 24-08-2008, 19:24
Though since for track systems i only know a few minor things about I figured I might ask around to team who have tried them to get a better idea...The funny thing is i didn't expect it to get unfocused and try to push me away from a track system.
You've gotten a pretty consistent answer: the best way to do tank treads is not to do them. It seems that most teams who have tried tracks don't do them anymore. There's probably a good reason for that.
Unread 24-08-2008, 21:40
System Ready...
AKA: Lynx
Do people fail to see i will not take that answer, i will not quit if i fail the first time, I'll try again until i get it right. I feel that since i put help into the title i would get only help and some talk about track systems. So in my mind i feel that if you going to post anything about going to wheels or saying flat out that tracks should not be used i will close this tread and only communicate to those that have given interesting ideas and help. So help me if enough people do this I'll close the tread and not support the post count that it has generated for you just to try to kill a plausible idea.
People seem to think i know nothing about wheels here or any other type of drive systems, That i may lack the understanding of advantages and disadvantages, that i may not know strategies or something...............................I'm sorry just please for the love of something just help me with my questions and not put some tiny little post saying not to do this. Personally i never said it was for competition, i never said it was for cool factor, i didn't say it was for a lot of thing but people here seem to assume. I don't know what to do anymore i think i have enough to live by that i don't need some people here being bias and persecuting a idea. Man i feel like i might as well be in the past trying to challenge the church or something for wheels.
Tank Treads??? SLA Kit & Additional Hardware 2 16-01-2007 20:53
Semi-Tank Tread/Half Tank Treads thoughtful Technical Discussion 4 11-01-2005 08:33
Tank treads snowdragon General Forum 0 21-01-2004 16:57
Tank tracks vs. Wheels MBosompra Technical Discussion 28 16-01-2004 23:31
Where Can I Get Some Wheels Or Tank Tracks? Alex Cormier Kit & Additional Hardware 5 13-01-2003 22:58
