Go to Post This problem will be solved by one of the largest problem-solving machines in the world...the FIRST community. - ZZII 527 [more]
Unread 22-08-2008, 23:11
EricH EricH is online now
Re: pic: Omnibot
Originally Posted by gimpnub View Post
why don't you use a three-wheel setup instead of a four-wheel setup?
correct me if i'm wrong but i think it would give you more stability and reduce your weight at the same time
your only difficulty might be programming it with 0, 60, and 120 degrees instead of 0, 90, 180, and 270 degrees, but there are also less wheels to program
i don't know how speed would be affected by the 3-wheel setup
if i'm wrong in any areas please forgive me and ignore my comments
Reduce weight, yes, but 3-wheel setups have to be carefully thought out. I can only think of 4 off the top of my head: 330 (2002) had a triangular robot and no omnis; 67 (2005) had a peculiar triangular setup that I don't quite remember, but it involved flopping down; 16 (2006) had a 3-wheel swerve with pads to keep the frame from hitting the carpet and digging in, and 148 (2008) had a 3-wheel swerve patterned off of 118's V6 and a much smaller robot than the other three. The only one of those that involved omnis was 67's, IIRC. I remember hearing that 67's drive code took up an awful lot of room on their controller...
More stability is debatable. If you've got it fully in a square or circle, possibly. But with a frame like this, I don't think so. You've got a big risk that one corner will go down and dig into the carpet.
Speed might not be affected. I'd have to do the vectors to figure that out, and I'm not in a position to do that right now...
Unread 23-08-2008, 00:18
Aren_Hill's Avatar
Build Nifty Things
Re: pic: Omnibot
Im almost completely positive 67 in 2005 was a 3 wheel swerve with no omni's involved.
you can see the front two wheels here : http://www.chiefdelphi.com/media/photos/20772
A guy who likes robots.
Unread 23-08-2008, 00:43
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: pic: Omnibot
857 did a 3 wheel omni, or "kiwi drive," in 2002
http://www.chiefdelphi.com/media/photos/13495
Unread 23-08-2008, 01:49
kajeevan kajeevan is offline
FRC #0188 (blizzard)
kajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud of
Re: pic: Omnibot
Right now its just a design but who knows I may just get to build one.
Unread 25-08-2008, 01:22
Re: pic: Omnibot
I'm pretty sure it was a kiwi-type system, like below. I tried to search, but no luck yet.
Unread 25-08-2008, 01:27
AdamHeard's Avatar
Lead Mentor
Re: pic: Omnibot
Nope, sorry Eric, but 67 definitely had a 3 wheeled crab in 2005.
Unread 25-08-2008, 01:31
Re: pic: Omnibot
Actually, I found a picture... of 67 2005... in a match... on two wheels, showing the third. NOT a true swerve. Swerve, yes. Three wheeled robot, yes. But not a three-wheel swerve. One wheel steered, three drove. Zoom in on the picture. One wheel is turned; the others appear not to be able to.
Unread 25-08-2008, 01:39
AdamHeard's Avatar
Lead Mentor
Re: pic: Omnibot
Actually, I found a picture... of 67 in 2005...during build... on the ground, showing all three wheels. A true swerve, with all three wheels able to rotate.
No hard feelings eric
Unread 25-08-2008, 14:16
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
Re: pic: Omnibot
If you move the wheels to opposite corners the math will work out exactly the same as it would for the configuration shown.
There are two advantages that a holonomic base built using this configuration has over a swerve drive:
1) The modules are lighter and less complex.
2) The robot can translate and rotate at the same time (I've seen this called "frisbee motion")
The programming is more complex, but there are plenty of examples available to get you started.
Unread 25-08-2008, 23:22
Re: pic: Omnibot
And rotate independently... No wonder the code took so much space in the controller.
Back on topic: If you're going to do 3WD, plan it out first. Carefully. As noted, only one robot (to our knowledge) has had a 3WD omni system; most of the other 3WDs were crab/swerve systems.
Unread 25-08-2008, 23:30
Joining the 900 Meme Team
FRC #0079
Re: pic: Omnibot
Also, the one robot that did a 3 wheeled omni (857) didn't use code to control their wheels, they used hardware (http://www.chiefdelphi.com/media/photos/16410) Dont forget that sometimes that solution works better than complex code. No reason to make the code more complex than it needs to be. Could it be done in code? Yes, is complex code always better? That is up to you.
Unread 26-08-2008, 20:15
Dowjonesbotics's Avatar
Dowjonesbotics Dowjonesbotics is offline
Leggooo
AKA: Jeremy Downes
FRC #1230 (Lehman Lionics)
Dowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the roughDowjonesbotics is a jewel in the rough
Re: pic: Omnibot
Cooool, are those the robots that spin really really fast??
My account had been hacked and used by someone random for the past 2 years, my apologies for so many awful posts.
2011 New York City Regional Regional Finalist
2009 New York City Regional Team Spirit Award
2008 New York City Regional Team Spirit Award
2007 New York City Regional Team Spirit Award
2005 New York City Regional Champion
2003 New York City Regional Rookie All-Star
Unread 27-08-2008, 17:05
1jbinder 1jbinder is offline
FRC #0852
1jbinder is an unknown quantity at this point
Re: pic: Omnibot
Hi
I like the design. Both my team(852) and an alliance partner at Davis 2144 built bots like this. They work well but can be a challenge to program. autonomous is almost impossible without a well coded gyro. Anyways give it a try and see what happens. That is what we did.
Julian
Unread 09-11-2008, 12:05
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Re: pic: Omnibot
Kiwi drive/Killough platforms are generally not any more stable than the 4-wheel holonomic drives. The arc lengths between wheels are larger than for the 4-wheels, meaning more area to tip. As for spacing the wheels out of a perfect square, yes, it works, but buy moving them out one more inch, you will require code of much greater complexity because of the angle calculations you will have to use to get the same effect. With the new control system, that shouldn't be a problem memory and speed wise, but it's just more things to crash in the program. Nice design, it's pretty!
pic: Omnibot Ryan M. Extra Discussion 18 03-08-2005 08:19
