Go to Post Course there's more than corn in Indiana... there's soybeans and wheat and hay and cattle and hogs and... oh never mind. :D - Jeremiah H [more]
Unread 23-06-2002, 22:42
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
interesting....
Posted by Anton Abaya at 1/20/2001 12:18 AM EST
Coach on team #419, Rambots, from UMass Boston / BC High and NONE AT THE MOMENT! .
In Reply to: 6WD -- Highly recommended...
Posted by Joe Johnson on 1/16/2001 9:33 PM EST:
hmmm....
can we borrow joe for like a day or two?
-anton
#0047 (ChiefDelphi)
Re: interesting....
Posted by Joe Ross at 1/20/2001 1:59 AM EST
Engineer on team #330, Beach Bot, from Hope Chapel Academy and NASA/JPL , J&F Machine, and Raytheon.
In Reply to: interesting....
Posted by Anton Abaya on 1/20/2001 12:18 AM EST:
: hmmm....
: can we borrow joe for like a day or two?
: -anton
Sure you can borrow me. What's a ticket to boston nowadays?
Oh, you mean that Joe
Joe Ross
Beach Bot, Team 330
#0047 (ChiefDelphi)
Re: A warning about tank steer (how to do 4WD effectively)
Posted by Chris Hibner at 1/17/2001 8:04 AM EST
Coach on team #308, Walled Lake Monster, from Walled Lake Schools and TRW Automotive Electronics.
In Reply to: Re: A warning about tank steer
Posted by CArobot on 1/16/2001 6:25 PM EST:
We are a team that uses 4WD and swears by it since it is powerfual and the robot is extremely easy to drive if done properly.
As Joe mentioned below, in a 4WD drive system, the wheels must scrub sideways as the robot turns. If you sum the moments about the robot as it turns, you will see that you need one of two things in order to turn effectively:
1) Your track must be larger than your wheelbase (considerably larger to be effective).
or
2) Your coefficient of friction between your wheels and the ground must be greater in the fore/aft axis than in the side-to-side axis. This is why we make custom wheels for our robot. We use metal or plastic and keep the edges of the wheel teeth "sharp" while we round the sides of the wheels. Then, voila! - you get a significant difference in the coefficient of friction from fore/aft to side-to-side. Of course, this only works if you are on carpet (or another surface that will deform under a wheel) and your wheel teeth are a good thickness. The wheels are esentially like skis - sharp in one direction and rounded and slippery in the other direction.
The residual friction in the 4WD system makes the robot extremely easy to drive since when you release the controls, the robot stops turning very quickly. Thus, the drivers don't really need to worry about compensating for overshoot in the turns.
I hope this helps anyone considering a 4WD tank steer system.
-Chris
[IMG] code is Off
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
What is crab steering?? Adam Y. Technical Discussion 18 30-12-2002 08:12
Under or Over? To tank or Not to tank that tis the question! archiver 2001 2 23-06-2002 22:53
Single Joystick Tank Steering archiver 2001 5 23-06-2002 22:49
tank steering archiver 2000 10 23-06-2002 22:28
