Go to Post This place is much brighter than most institutions I have seen. It also seems to be lacking straight jackets which I think is a mistake for many of us. - Andrew Schreiber [more]
Unread 23-06-2002, 22:43
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Center of Gravity = 24"
Posted by mike o'leary at 1/16/2001 10:09 AM EST
Student on team #419, rambots, from bc high.
In Reply to: Re: Center of Gravity = 24"
Posted by Raul on 1/12/2001 10:18 AM EST:
has anyone out there done rauls math? T(L-x) = Bx? anser would be interesting
mike oleary
There is another way to find the CG;
: Put the top end on a scale while the base sits on the floor - take a weight reading. Then put the base side on the scale and the top on the floor - take a reading.
: If 'x' is the distance of the CG from the base,
: 'L' is the diatance from base to top,
: 'T' is weight (force) at top,
: 'B' is weight at base, then:
: T(L-x) = Bx
: So just solve for 'x' and you have it.
: It will be even more accurate if you have two scales and can weight both end simultaneously and can keep the goal horizontally level (prope the scale up). This technique works for most long objetcs. Hope that helps.
: Raul
: : I didn't really have a good way to do this, but here's what I did:
: : I placed the goal on it's side, on top of two stacked 4x4 boards. I got the goal to balance on the boards. Then, I measured the distance from the bottom edge of the casters (where the floor would be) and the center of the balance point.
: : And that distance was 24".
: : Your mileage may vary.
: : Andy B.
[IMG] code is Off
2002 game prediction contest!!! Ken Leung Rumor Mill 41 31-12-2007 18:18
Who should build the field? Rich Wong General Forum 17 08-03-2006 17:38
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Looking for full playing field archiver 2001 1 24-06-2002 00:13
Lego field wanted--URGENT!!! David Kelly General Forum 0 19-11-2001 12:17
