Go to Post For some people FRC is an introduction into STEM and just a way to open someones eyes to a world they might not know exist. To other it is a lifestyle that makes crossfit look casual. - IronicDeadBird [more]
Unread 28-08-2008, 15:09
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: Capabilities of a Hall-Effect sensor
Originally Posted by Michael Hill View Post
Like I said, I'm not counting the blades, I want to know how close the blades are to the casing. (i.e. the sensor) ...
Yes, I know. The Allegro sensors do output an analog voltage proportional to the magnetic field ... so the closer the blade, the higher the reading. The sensor has to react fast enough to detect each and every blade as it passes - you need it to react even faster to detect the nearest point of the blade.
I think the problem with magnetic sensors here though is the material - surely it has it's own magnetic properties, which might vary from blade to blade? I think optical is better.
Hall Effect Sensor Transmission Placement robotoby35138 Electrical 1 06-02-2006 18:43
The Hall Effect sensor wiring? LaughingJack Electrical 11 21-02-2005 13:35
Hall Effect Sensor Example Code JJMax7 Programming 6 16-02-2005 02:38
Hall effect sensor Filtering magical hands Programming 5 13-02-2005 11:23
Hall Effect Sensor. Nixterrimus Electrical 77 29-01-2005 10:48
