Go to Post Different approaches to the same problem. Isn't it better to focus on understanding both than to be dogmatic about it? - Greg McKaskle [more]
Unread 23-06-2002, 22:43
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Not so Sure
Posted by Matt Leese at 1/12/2001 10:36 AM EST
Other on team #73, Tigerbolt, from Edison Technical HS and Alstom & Rochester Institute of Technology.
In Reply to: Not so Sure
Posted by aTm on 1/11/2001 3:39 PM EST:
Well, here's the rub about the black balls: There are four robots out on the field. They all really should be doing something. Just sitting there helps no one. The idea therefore is as soon as the first one gets across the ramp, it starts picking up the black balls while the others are waiting to cross or doing things on the near side. There's a limit to what number of things can be done. Make use of the whole alliance and get out of the thinking that you're the only (or even most important) robot out there.
Matt
[IMG] code is Off
