Go to Post Once you get to college, remember that FRC is not your life anymore (or at least it doesn't have to be). Don't be afraid to try new things, and branch away from the things you swear by in high school - buildmaster5000 [more]
Unread 02-09-2008, 21:24
starsROBOTICS starsROBOTICS is offline
FRC #2276 (S.T.A.R.S)
starsROBOTICS is on a distinguished road
What is duty cycle?
I was reading on labview about pulse width modulation and i came across duty cycle.
Can someone briefly explain what that is?
Unread 02-09-2008, 21:26
Re: What is duty cycle?
A quick search on "duty cycle" turned up the following recent thread: http://www.chiefdelphi.com/forums/sh...ght=duty+cycle
Unread 02-09-2008, 21:31
ok now that i got that what is a standard frequency to use with the motors provided by first?
Unread 02-09-2008, 22:15
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
I don't mean to be rude but please use the search tool before posting, you have had multiple posts that can be easily found with a simple search.
and now the question, the IFI system uses 60Hz, and the new system for 2009 uses 20KHz.
Please before posting.
-Borna Emami
Team 0x27
Unread 02-09-2008, 23:39
Gdeaver Gdeaver is offline
FRC #1640
If one searches on the IFI Victor web page, they state that the Fet chop rate or PWM fequency is 120 HZ. The controller must send a low for at least 8 ms before the victor can recieve the next updating 1 to 2 ms pulse. The press release for the new speed controler did state that 20 khz was the fequency for the new one. For many reasons they may find that a high fequency ia not always a good thing. The big change with the new speed controller is the powerful 32 bit microcontroller and the can buss interface. The controller is reprogramable so as the needs of First change the controller can be upgraded and it's capabilities expanded.
Unread 03-09-2008, 11:57
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
The new speed controller does output a 20kHz PWM to the motors, but that is separate from the input signal. For 2009, the input will be the standard PWM servo signal, as used with the IFI system. Once the CAN interface is opened up for use, probably in 2010, we should be able to send a signal at 20 kHz.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Call of Duty 4 Danny McC Games/Trivia 2 11-11-2007 21:26
Motor duty cycle / advice on a non-FIRST project SiliconKnight Technical Discussion 2 01-04-2003 15:02
Jury Duty archiver 2000 6 23-06-2002 22:21
