Go to Post Then as soon as we get the kit loaded into the back of my truck, we ferociously rip it open screaming "How many CIMs!?" - sanddrag [more]
Unread 05-09-2008, 10:08
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: Kalman Filters
The first I heard of Kalman Filters was in articles related to the Darpa challenge ... it was my impression it was a means to process signal inputs AND combine inputs from multiple sensors (like wheel encoders plus gyro plus accelerometer) into some sort of matrix which would evaluate the most correct decision data.
From reading this thread I now understand that the Kalman Filter is a means to extract a good signal (opinion/estimate) from a noisy one - usually from ONE sensor.
Since it seems that the Kalman Filter is a very advanced topic, in First we can use simpler filtering techniques such as moving averages, throwing out "obviously bad" minimum and maximum sensor readings, and more advanced filters such as FIR and FFT. Some more discussion about filtering sensor inputs, and combining multiple sensors into decision-making software, can be found at http://www.servomagazine.com/search.php and searching for filter.
Searching for sensor fusion on the same site produces some interesting articles about combining multiple sensors to make decisions, particularly the July and August 2006 articles entitled "Autonomous Robots and Multiple Sensors".
Unread 05-09-2008, 17:46
Samuel H. Samuel H. is offline
Rookie Year: 1000
Samuel H. has a spectacular aura aboutSamuel H. has a spectacular aura about
Re: Kalman Filters
Actually, because the Kalman filter is based on matrix operations, it is very flexible and can be used for varying numbers of sensors and state variables. For a comprehensive set of links see http://www.cs.unc.edu/~welch/kalman/
Unread 05-09-2008, 18:14
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Re: Kalman Filters
Several summers ago, a college mentor from FRC 931 built a low cost self-balancing scooter as a demonstration project while working as an intern in my lab at Emerson. His creation looked very much like one built earlier by Trevor Blackwell. Both versions employ Kalman filters to correct for drift in the tilt angle estimated by integrating a gyro's output.
While that student has gone on to pursue PhD level work since then, he had never heard of a Kalman filter before starting the project. Full comprehension of the Kalman filter's mathematical beauty requires the kind of study that previous posters in this thread have described -- and that study is rewarding for its own sake. However, you can apply what others have done without getting to that depth.
Yes, the mathematical basis for balancing an inverted pendulum really is rocket science. Be encouraged by the evidence that the math works, not intimidated by its beautiful details.
Richard Wallace
since 2003
Unread 05-09-2008, 19:22
nickmagus's Avatar
nickmagus nickmagus is offline
AKA: Nick Clayton
FRC #0008 (Paly Robotics)
nickmagus is an unknown quantity at this point
Send a message via AIM to nickmagus
Re: Kalman Filters
its true i can utilize someone else's implementation but i don't like to do that unless i at least understand their implementation myself. and typically apart from basic framework code (which is a pain) i like to implement code myself (or use code implemented by my teammates) its just hard to properly use code that you don't understand. for example i was looking at the code for an old robot fixing it up and i found the PID loop was adding the D term to the output which is exactly the opposite of what you want so i like to at least understand the basics (including the basic math) behind the code i write. Anyone can use someone else's algorithms but if they don't try to understand them they get nothing from it. so when i wrote a auto tune loop for a PID earlier this year based on zigler-nicoles it was only after reading an entire text book from a cal tech course (which was fascinating and free btw i recommend it http://www.cds.caltech.edu/~murray/a...itle=Main_Page)
Unread 05-09-2008, 21:31
Re: Kalman Filters
Originally Posted by nickmagus View Post
its true i can utilize someone else's implementation but i don't like to do that unless i at least understand their implementation myself. ...
OK, so you like the beautiful details. I do too.
BTW, the former FRC 931 college mentor that I mentioned above is Brandon Heller. He is a PhD student at Stanford now. I think he also was one of the mentors for FRC 8 (your team) last year.
As Sam mentioned a couple of posts up, Kalman filters are good for much more than just figuring out which way is up (whatever your frame of reference). Your exploration of the details might lead to applications beyond balancing an inverted pendulum, and one of those might find its way onto your team's next robot. Have fun with it.
Richard Wallace
since 2003
Unread 05-09-2008, 23:20
nickmagus's Avatar
AKA: Nick Clayton
Re: Kalman Filters
ya he was a mentor of ours last year. Im not sure of his status this year but thanks i'll ask him about it. but first for research into the beautiful details and some other concepts in control theory, beyond what i already know. thanks all for your help and support.
Collaborate on LabView virtual Kalman robot? KHall Technical Discussion 3 09-06-2008 23:18
Kalman Filter for Heading information. Tatsu Programming 1 22-02-2007 02:20
Digital Filters? archiver 2000 2 23-06-2002 22:55
