NXT - 884 Speed Controllers
Is it possible to use the Lego NXT Brick and send signals to the IF 884 Speed Controllers? If so how?
Re: NXT - 884 Speed Controllers
Not a stock method... You see, Victor 884s take a PWM input using a standard 3-pin PWM cable. The NXT outputs its (whatever type of) signal on a relative of an ethernet cable. So you'd have to figure up a new connector. It's doable (teams have interfaced an NXT to the robot controller) but it isn't built in. I don't know what sort of pin mapping you'd need to do, though I'm sure someone might be able to help.
This is what FIRST will be using for FTC: http://www.hitechnic.com/index.html?...arget=d14.html
| extra Victor 884-Speed Controllers? | team1405 | Control System | 4 | 30-01-2005 01:03 |
| extra Victor 884-Speed Controllers? | team1405 | Electrical | 4 | 30-01-2005 01:03 |
| Speed Controllers | archiver | 2000 | 2 | 24-06-2002 00:08 |
| Speed Controllers | archiver | 2000 | 1 | 23-06-2002 23:01 |
| Speed Controllers... | Tom Schindler | Technical Discussion | 4 | 13-12-2001 17:26 |
