Go to Post If you need persuasion woven tight with logic, leave it to a software architect. - Richard Wallace [more]
Unread 07-09-2008, 20:41
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: Why to use LV/C++/C?
Originally Posted by Alan Anderson View Post
(C/C++ is procedural, LV is functional)
You should probably look up what "functional programming" means (try Wikipedia). Being Object-Oriented doesn't appreciably change C++'s imperative nature. What you've written seems similar to "While an orange is a fruit, a navel orange is seedless."
Ah. Thank you for clearing that up.
Why Not Use ISM band? Mr-Shutter Control System 8 06-06-2007 21:03
Why you should use Gmail Nathan Chit-Chat 5 22-02-2007 00:20
Why use the RC to control Pan/Tilt Joe Hershberger Programming 15 30-01-2007 23:41
Why would you use FIRSTwiki? Max Lobovsky FIRSTwiki 4 18-07-2004 23:59
Why can't you use 255 in PWM? Andrew Technical Discussion 4 29-05-2003 14:50
