Go to Post For what it's worth, while they may or may not be legal as safety glasses, Steampunk goggles are perfectly legal as forehead protectors. - Nuttyman54 [more]
Unread 23-06-2002, 22:48
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Can we really get 225 in-lbs from the drills?
Posted by Jason Rukes at 1/12/2001 1:53 PM EST
Engineer on team #109, Arial Systems & Libertyville HS, from Libertyville High School and Arial Systems Corp & SEC Design.
One of Woody's slides during the Kick-Off showed that a current-limited motor will have the same max speed, but less torque than a "current-unlimited" motor. That got me thinking about the drill motors and the effect of the 30A circuit breaker.
The datasheet states the drill motor will stall at 225 in-lbs(low speed). The torque constant is 5.836mN-m/Amp which means the motor can only generate 62in-lbs of torque at 30 amps before tripping the breaker.
Does this sound correct?
#0047 (ChiefDelphi)
Re: Can we really get 225 in-lbs from the drills?
Posted by Raul at 1/12/2001 1:58 PM EST
Engineer on team #111, Wildstang, from Rolling Meadows & Wheeling HS and Motorola.
In Reply to: Can we really get 225 in-lbs from the drills?
Posted by Jason Rukes on 1/12/2001 1:53 PM EST:
The breaker does not really trip at 30A. I do not know the specs but it will typically allow quite a bit more current for a certain amount of time.
Raul
: One of Woody's slides during the Kick-Off showed that a current-limited motor will have the same max speed, but less torque than a "current-unlimited" motor. That got me thinking about the drill motors and the effect of the 30A circuit breaker.
: The datasheet states the drill motor will stall at 225 in-lbs(low speed). The torque constant is 5.836mN-m/Amp which means the motor can only generate 62in-lbs of torque at 30 amps before tripping the breaker.
: Does this sound correct?
#0047 (ChiefDelphi)
you get all that and more
Posted by Joe Johnson at 1/12/2001 3:14 PM EST
In Reply to: Re: Can we really get 225 in-lbs from the drills?
Posted by Raul on 1/12/2001 1:58 PM EST:
My experience is that you get all that and more.
The motor is a .6N-m motor. In low, you have a 64:1 ratio. .85-.90 per stage and 3 stages, the effective stall torque is between (low est) .6*64*.85*.85*.85 = 23 N-m or 210 in-lbs and (high est) .6*64*.9*.9*.9 = 28 N-m or 250 in-lbs.
From playing with the transmissions over the years, I estimate that it is closer to the second than the first.
Joe J.
P.S. The breaker does trip but not for a while.
[IMG] code is Off
drills and chips Ben.V.293 Technical Discussion 1 07-11-2003 13:11
2003 Drills and Chips Chris Motors 3 12-10-2003 19:02
Image Discuss: Team 225 CD47-Bot Robot Showcase 3 10-02-2003 23:04
drills and gear housing... archiver 2001 4 23-06-2002 23:46
Bosch drills Joe Turner Motors 3 11-02-2002 13:56
