Go to Post To label hard work as unfair is really a bitter assessment. - Koko Ed [more]
Unread 09-09-2008, 20:41
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: A few Labview questions
To add on to that a bit, joysticks and other potentiometer-based game controllers are definitely not the only way to control a robot. The most obvious way to control a robot would actually be to not control it at all; make it fully autonomous. For that there is definitely benefit in testing beforehand (this testing is actually quite possible, considering that the drive system on the robot changes little). However, there's also several forms of semi-autonomous control. One of them would be simply running an autonomous program and interrupting it as necessary. What I'm working on is a picture-based setup where you have a map of the field and all obstacles the robot can see, and you assign it a route or tell it to manipulate something on the field. If you're interested, I have the very beginnings at http://sotabot.com/robot/programming.html The file is called "robot tracker", but I use some of the other VIs in it, and you might have to download them as well.
Good luck, and keep asking questions; you're clearing things up for us too.
-- Marshal Horn
A few questions Magnechu Rules/Strategy 8 25-01-2008 17:01
Few questions rohit Inventor 5 07-03-2007 09:07
A few questions... Ryan Dognaux 3D Animation and Competition 3 19-02-2005 22:48
A few questions cheezewiz Programming 7 31-01-2004 00:02
A few questions goegan31 Regional Competitions 1 09-03-2003 20:32
