Go to Post I am proud whenever I turn to a team during inspections and say "OK I just need two signatures here and I will go get your sticker, you passed!" - Al Skierkiewicz [more]
  #31   Spotlight this post!
Unread 04-09-2008, 15:32
Spartan151's Avatar
Spartan151 Spartan151 is offline
TCU Bound (Class of 2013)
AKA: Sean
FRC #2920
Spartan151 will become famous soon enough
Re: T-Shirt cannon pnuematic set ups
Okay. I've been following this for a couple days. I figured that a t-shirt cannon would be a nice idea for our team, since at least half of us are graduating this year. This leads me to ask some questions before attempting a build.
Question 1: In regards to the air tanks, what kind of material could I use for pressurized air storage?
Question 2: Is it possible to use a high-pressure rated tank or such for a "rifle-style" t-shirt cannon without the need of having to carry around a storage tank?
Question 3: On the barrel part, since I DON't plan to use PVC for storage, can I use a strong duct tape-wrapped PVC pipe for just a place to load the t-shirts?
Question 4: What is the best way to design one that is safe? (We don't have a huge budget, so buying one is a bit of a problem.)
Question 5: What kind of sprinkler valve/solenoid should I use and where can I get one from?
MORE DUCT TAPE!
  #32   Spotlight this post!
Unread 05-09-2008, 01:23
Mr. Freeman Mr. Freeman is offline
Put better title here.
AKA: Kellan
no team (CSM Robotics)
Mr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to beholdMr. Freeman is a splendid one to behold
I don't know what thread it was in, but someone on this forum posted awhile back about doing some tests and finding that duct tape doesn't prevent shrapnel.
"Time is an illusion, lunchtime doubly so."
-Douglas Adams
“Why is it that I can walk into Wal-Mart and buy boxes of bullets and black powder, but I can’t buy potassium perchlorate to do science because it can also be used to make explosives?”
-Theodore Gray
  #33   Spotlight this post!
Unread 10-09-2008, 12:24
Spartan151's Avatar
AKA: Sean
FRC #2920
Well, I've been tinkering, looking at Fusion's setups, and I've come up with my own design. Now, I wouldn't go replicating the idea I'm going to post if I were you, not until I give some feedback on how it did.
Here's the setup. I took a two foot long, 3-inch PVC pipe, added a 3in. coupler, put a 3-to-1 1/2 reducer, then a 1 1/2 to 1 reducer, to fit the Rainbird Sprinkler Valve. The Sprinkler Valve electrical system I'll explain later.
keep in mind that the PVC IS NOT USED FOR AIR STORAGE AT ANY POINT ON THE GUN! the only time it comes in contact with air is when the gun fires, and even then it's triple-reinforced in the joint sections, and I made sure to take an extra careful amount of time while assembling it.
Next, I plan to get hold of some tubing that can be pressurized to at least 110 PSI. This will enable me to have a variable adjustment rate without a risk of bursting. The hose will run to a connector, which will be tapped to an old Freon tank, much like Fusion's design. The tank will have a fill nipple, a pressure gauge for the tank, a hand valve for on/off, a regulator, another gauge for the regulator, and then the place to mount the hose.
As for electrical, I bought one of those little black boxes from Radio Shack, took a toggle switch (One of those that has a protective cover over the switch to prevent accidental turn ons). this switch acts as a safety. When this switch is on, a red light on the panel part is on, and a bright blue light powers up on the side. two of the 9v batteries are inside the box, and one 9v is outside of it attached by a "cradle". This allows me to pull the battery off for mainenance purposes, or simple power down. Next, the wires run to a "trigger" setup, and then to the solenoid wires itself, for activation of the valve.
Again, I wouldn't recommend attempting this until I have posted back with lots of feedback and testing results. If you do, okay, but I hope you take the time to think things through. I don't want to hear of someone getting hurt because of my design. Better me than you. Good luck, cannoneers.
MORE DUCT TAPE!
  #34   Spotlight this post!
Unread 10-09-2008, 12:55
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
1> Use steel or aluminum tanks rated for 3x higher than your working pressure. Other materials may be used but stay away from PVC as it fails explosively.
2> You can use a smaller High pressure tank. The compressed air will weigh the same and the tank will weigh less. Again I suggest a 3x safety margin from storage pressure. Also, you will need to regulate down from this high pressure and that may cause restriction in the air flow.
3> Duct tape does virtually nothing if the PVC fails. DO NOT USE PVC. I cannot stress more that PVC does not like the shock loads that an air cannon provides and when it fails (not if) it will fail explosively.
4> Understand the forces used and the gas laws that apply (especially that gas exerts the same force in all directions ... not just out the barrel). Design with safety in mind and always err on the side of caution.
5> You need a valve with a large orifice that unseats quickly. Many have chosen sprinkler valves for this type of use ... but I'd look closer at vane valves myself.
Good luck and play safe.
___________________
- Tennyson, Ulysses
  #35   Spotlight this post!
Unread 10-09-2008, 13:01
Mad Scientist
AKA: Me
FRC #2040 (DERT)
The PVC barrel will see a shock load that is equal to the pressure in the tanks. This shock load will be applied in under 1ms. It is this shock load that will sunder PVC as the PVC cannot expand fast enough when the shock load is applied (cannon is fired).
Again, I highly recommend not using PVC for ANY pneumatic device ... especially ones that will sustain shock loads such as air cannons.
___________________
- Tennyson, Ulysses
  #36   Spotlight this post!
Unread 10-09-2008, 14:27
Spartan151's Avatar
AKA: Sean
FRC #2920
Okay. I wanted to clarify that, and it's a little easier to understand when you put in in terms of a shock load. I've got some other tubing for backup in case it wasn't going to work, with all the fittings ready. Thanks for clarifying that.
grateful, Sean
MORE DUCT TAPE!
  #37   Spotlight this post!
Unread 10-09-2008, 20:38
rokenboker rokenboker is offline
FRC #1236
rokenboker is an unknown quantity at this point
team 1236 here and i have built one and it works great!
here goto this page on the site
http://www.chiefdelphi.com/forums/sh...ad.php?t=69073
  #38   Spotlight this post!
Unread 20-04-2009, 19:01
Beener Beener is offline
Innovation First, Inc.
VRC #0148 (Robowranglers)
Beener has a spectacular aura aboutBeener has a spectacular aura aboutBeener has a spectacular aura about
This is what we came up with.
  #39   Spotlight this post!
Unread 17-05-2009, 20:33
Adama's Avatar
Adama Adama is offline
AKA: Matthew Eastman
FRC #2199 (Robo-Lions)
Adama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to all
Send a message via AIM to Adama
If in fact PVC is incredibly dangerous I have a few questions.
The discussion here has been only about air powered guns. Is there any greater or less danger in combustion guns? ( I'm aware that this would be disallowed on school grounds, its just a question of principle) I imagine that the lack of high pressure storage gives some what more safety though there is more of a spiking pressure affect that could counter act this.
Also on the topic of air cannons what are peoples opinions on the below link?
http://www.spudfiles.com/
I realize that it is the internet and not a well researched set of standards but one must question the danger involved if there has been a large community of people using these devices for years now. They have there share of accidents (as does any hobby such as dirt biking or snow boarding, etc) but it would seem that they only happen to people who didn't follow the well known safety practices and construction techniques established over time by the general spudding community. I guess that that if PVC were as dangerous as we are discussing then most of these people would have killed themselves by now.
  #40   Spotlight this post!
Unread 17-05-2009, 21:02
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
I would definately say thats a combustion gun would be even more dangerous
PVC SHOULD NOT to be used EVER for anything being pressurised except for WATER and this should be the end of it(unfortunately it most likely wont )
and on the topic of alot of people using PVC, I belive there just asking for it, but its thier decision
Ill' give you that PVC dosent ALWAYS explode(which is why alot of people use it) but IF it does,someone COULD be seriously hurt, I dont know about you guys, but I would rather not risk having someone else injured because of me
I also belive this has been said before MANY MANY times by far more experience people than me
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
  #41   Spotlight this post!
Unread 18-05-2009, 14:08
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
This is the most reoccurring issue with air launchers and combustion "guns". PVC is extremely dangerous!!
The PSI rating printed on the pipe is for liquids NOT compressed gases of any sort. The biggest problem with PVC is that its failure, when it occurs, is catastrophic. PVC shatters into numerous sharp shards that can be propelled at dangerous levels. PVC generally will not exhibit signs of fatigue until it explodes. People have also argued that PSI is PSI, so why isn't PVC safe with compressed gas? By the very natural of solids, liquids and gases, gases will release stored energy much faster than a liquid will, even liquids can still dangerous.
As far as your logic of a lot of people using these devices and none being hurt. That is a falsehood perpetuated by the internet. I have seen posting of failures but they are few and far between because most people don't want to post their failures, only their successes, and they certainly wouldn't post if someone was injured (don't you think the lawyers would love to get their hands on that incriminating evidence). Also, in most cases these people use these devices a few times before tiring of them, or getting caught (combustion guns). They've rolled the dice a few times and lucked out. PVC failure is generally from fatigue which means each time you load and unload the pipe you stress it and each time your chances of a failure increase. Load that pipe enough times and it will certainly fail.
I personally know at least four incidents of PVC failures. Luckily, no one was seriously hurt ONLY BECAUSE OF PURE LUCK! In one case, an individual had a charges air launcher under his coat. Luckily it failed away from his body, but it completely shredded a heavy winter jacket being worn. If you saw the jacket, you'd think the person wearing it was DEAD! Pure Luck plain and simple.
Our Dewbot T-shirt air launcher is built with an all metal storage accumulator, piping, and valve system in which every component used was rated at over 150 PSI. Where we used flexible hose (after the solenoid valve) it was rated at over 180 PSI and is reinforced so that a rupture would only cause a tear in the material. The launcher tubes are made out of polycarbonate pipe which is rated at 9000 PSI and was $11/foot. That should give you some idea of how seriously we took safety when using plastic pipe, even polycarbonate.
Don't be misled by what you don't find on the internet.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
  #42   Spotlight this post!
Unread 18-05-2009, 14:32
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Originally Posted by gorrilla View Post
pressure rated pvc pipe is perfectly fine to us as long as you dont exceed the rating
abs plastic is not pressure rated but when it fractures its like safety glass on a car YOU SHOULD NEVER USE ABS PIPE
steel pipe is the best but most people dont have lots of money for steel pipe
bottom line you can use pressure rated pipe as long as you are smart and dont exceed the rating
It terrifies me when people make posts like this without understanding they may very well be placing somebody in harms way.
I wonder what type of professional engineering or material engineering degree this person has. I wonder what license and what expertise are this person bases his statement on.
OSHA and the manufacturers say NO.
http://www.osha.gov/dts/hib/hib_data/hib19880520.html
  #43   Spotlight this post!
Unread 18-05-2009, 18:35
AKA: Kellan
No offense, but I could ask you the very same question. I don't think you've explained what degree you hold.
-Douglas Adams
-Theodore Gray
  #44   Spotlight this post!
Unread 18-05-2009, 18:55
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Combustion guns use expanding gasses to propel the object, and therefore are still inherently dangerous to use PVC with. In addition, the lack of specific gas pressure control and the addition of heat will most likely cause the PVC to fatigue faster.
People will always do stupid things and then brag about their "success". Don't be the one that "fails".
Please take it from someone who has had a 1 liter volume, pressurized to 100 PSI, blow up on him at close range (ME). It is dangerous, very dangerous.
___________________
- Tennyson, Ulysses
  #45   Spotlight this post!
Unread 18-05-2009, 19:06
Adama's Avatar
First of all I have read the entire thread and am well aware of the facts you stated in red text several times before. I wasn't speaking so much as in defense as more of an awarness of a very large community. It was an attempt to bring to light more than what had been discussed already. The internet is and can be very misleading but none the less it is present and full of more empirical data (probably positively biased) and trial and error on the subject than can be completely ignored.
On a side note I have built and operated a combustion gun for several years now. (if you can't make one you probably shouldn't have one ) Its stored inside away from temperature extremes, I do not fire it in extreme cold, I use weak fuel such as hairspray and I always treat it as an actual fire arm. That is why I was probing into combustion guns.
pic: Fully Automatic Tee Shirt Cannon - Pic 2 artdutra04 Extra Discussion 23 26-07-2015 13:20
pic: T-Shirt Cannon at Purdue's Homecoming jtdowney Extra Discussion 10 08-11-2007 19:48
IRI T-shirt cannon Kyle Love Off-Season Events 6 17-07-2007 12:09
pic: 549's t-shirt cannon and ballon inflator w/ horn griff549 Extra Discussion 2 06-05-2007 00:36
pic: UPS with UPS Kevin Kolodziej Extra Discussion 10 04-05-2005 12:57
