Go to Post All tools are powered by magic angry noise. - artdutra04 [more]
View Poll Results: Yes or no the to the award?
Yes 42 57.53%
No 31 42.47%
Voters: 73. You may not vote on this poll
Unread 12-09-2008, 14:25
Re: should there be a award for programming skill?
Originally Posted by tawnos23 View Post
...an award for good practices and style would make us programmers more focused on good technique and style.
Then who decides what "good style" is? How do you determine "good technique" from a finished program?
In c, which would you award points for: putting curly braces on the same line as the if statement, or putting them in the same column? Do you penalize a test for equality to one because it's redundant, or do you reward it because it's clearly readable? Do you want to promote block comments or line comments? What do you think of Hungarian Notation? How would you grade Duff's Device?
I just don't think it's a good idea to try to judge style. I don't think it's possible to do so unless there's a single person doing the judging, and I think there is too much subjectivity about what makes style "good" to make it a positive experience for those involved.
Is there any software that does C programming for you? THE_SDMC Programming 10 24-01-2007 18:32
Should there be a section for the 'camera' under 'Programming' Bharat Nain CD Forum Support 6 25-01-2005 22:23
What should I put on my programming jump drive? IMDWalrus Programming 10 15-01-2005 13:37
Should the Chairmans Award be Mandatory? Josh Hambright Chairman's Award 43 30-09-2003 13:16
Driving Skill Andy Grady General Forum 24 23-03-2003 02:34
