Go to Post ..this is the first robot we've built that succeeded at everything we wanted it to. It was simple. It was low maintenance. It scored effectively. It had an autonomous that worked. Its look caught attention. And it was finished on schedule. - Donut [more]
View Poll Results: Yes or no the to the award?
Yes 42 57.53%
No 31 42.47%
Voters: 73. You may not vote on this poll
Unread 12-09-2008, 20:00
Kyle Fenton Kyle Fenton is offline
GET IT ON!!
FRC #0121 (Rhode Warrior)
Kyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud ofKyle Fenton has much to be proud of
Send a message via AIM to Kyle Fenton
Re: should there be a award for programming skill?
Judging the pure layout of code is highly subjective, and will probably would never be judged in a consistent manner. There are definitely bad ways of programming, but there are also several good ways too. But in the end it all depends how well the code executes on the field.
One award that I always wish FIRST would consider would be a potential innovation award. Several teams including mine would try some bold and innovative that would have given them a clear advantage in the field. However for one reason or another it didn't work because of a limitation beyond their control (mechanical, processing power, # of i/o, etc). Often this could be a unique sensor, or a better way to navigate through autonomous. If the team can successfully explain what the feature was, and what constraints they need to resolve it, then they should be rewarded for their hard work. The short time in the build season often doesn't permit for much Test and Evaluation (T&E).Many times, some crazy and innovative programming ideas get dropped for more conventional ideas.
Rhode Warriors
NAVSEA/Raytheon/URI/Middletown, Portsmouth, Tiverton, Mt. Hope HS
Quality Robots Since 1996
Is there any software that does C programming for you? THE_SDMC Programming 10 24-01-2007 18:32
Should there be a section for the 'camera' under 'Programming' Bharat Nain CD Forum Support 6 25-01-2005 22:23
What should I put on my programming jump drive? IMDWalrus Programming 10 15-01-2005 13:37
Should the Chairmans Award be Mandatory? Josh Hambright Chairman's Award 43 30-09-2003 13:16
Driving Skill Andy Grady General Forum 24 23-03-2003 02:34
