Go to Post You know you've been in FIRST way too long when you can remember all those hints... even down to exact wording... and only have to look up the most recent. - EricH [more]
Unread 23-06-2002, 22:51
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Piston power?
Posted by Seth at 1/13/2001 10:18 AM EST
Student on team X-Cats from Wilson Magnet HS sponsored by Xerox.
we are considering using pistons as a way to pull the goal closer to our bot. has anyone calculated the amount of force that will be needed to do that?
#0047 (ChiefDelphi)
No problem
Posted by Mark Garver at 1/13/2001 11:20 AM EST
Student on team #68, Truck Town Terror, from Waterford Kettering/OSMTech Academy and General Motors Truck Group.
In Reply to: Piston power?
Posted by Seth on 1/13/2001 10:18 AM EST:
An air piston can pull the goal with very little problem, figuring you are using a 2" bore
#0047 (ChiefDelphi)
Re: No problem
Posted by Justin Stiltner at 1/15/2001 12:52 AM EST
Student on team #388, Epsilon, from Grundy High School and NASA, American Electric Power, Town of Grundy.
In Reply to: No problem
Posted by Mark Garver on 1/13/2001 11:20 AM EST:
: An air piston can pull the goal with very little problem, figuring you are using a 2" bore
To find the force that the pistion will put out use the formula F=AP where F is Force A is area of the inside bore of the cylender and P is pressure
Justin Stiltner
Team #388
Epsilon
Grundy Va,
[IMG] code is Off
power to the pits Ken Leung Off-Season Events 12 11-05-2003 22:48
URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! kmcclary Electrical 8 10-10-2002 10:56
4WD with 4 motors archiver 2001 8 23-06-2002 22:58
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
