Re: pic: Mammoth GearBox1
If you are going to make those on a regular CNC milling machine, then it would be SO much faster to fabricate by making the outside of the plates square. That way, you can just stick the plate in a vise and mill out the bearing holes and pockets (as opposed to mounting it onto a fixture plate, and mounting that inside the milling machine, then having to mill out the pockets and holes, as well as go around the outside to make the curves...).
Also, if the aim is weight savings, I would lighten the gears well before I would start pocketing the side plates to that extent. All it takes is two operations on a milling machine (either CNC or manual with DRO and rotary table) to make these. Depending on the gear size these can save quite a bit of weight. ![]() |
Theres some good advice on this thread, hope you are seriously considering what they said, rc_cola.
One item not yet covered - if you are going to use a sprocket on the output shaft to drive a chain drive, you should think about the shaft loads that will result from the chain when the motors are at full load and the wheels are stalled. The chain load can be pretty high for a drive with this output torque. One other thing you might consider - the standoffs that you are using there look pretty skinny. Along with making sure you have adequate strength of the sideplates (as Greg already said), I would make sure you have enough contact area between the standoffs and the side plates. Ken |
Thanks for all the suggestions:
-Pocketing the gearboxes was because we wanted to try out the CNC and with Cosmos it tells us that the plates are plenty strong enough. They are 7068 plates at 1/4 inch. So the plates are just for fun. -The mentors were going over the specs and said that the 3 inch cims would be better for a 2 stage reduction. Thanks everyone. |
And as for the big CIMs, all things being equal, it's probably sensible to get rid of those somehow. |
I suppose you really want to make a gearbox... because a tough box with spacers weighs only 1.77 lbs...
How big is the mammoth? Will you be mechanizing the head? If you do, post some pics, since that sounds really cool! Last edited by =Martin=Taylor= : 15-09-2008 at 17:47. |
Andy B. |
#7
Edit: Looks promising. How's the 6061 holding up? Last edited by Travis Covington : 15-09-2008 at 18:15. |
#8
thanks, Vivek |
#10
| pic: team 1305 - The Mammoth | Ayu | Robot Showcase | 2 | 04-03-2004 23:33 |
