Go to Post You know, if I was John V-Neun I would get a copyright on my name! - Jay H 237 [more]
Unread 23-06-2002, 22:51
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
More things to think about...
Posted by Joe Johnson at 1/13/2001 10:01 PM EST
In Reply to: Re: Four motors at the same speed?
Posted by Dodd Stacy on 1/13/2001 4:16 PM EST:
As usual, Dodd hits the target dead on.
I have one or two things to add though.
There are other options besides gearing the motors so
that they match free speeds.
You can gear them to match stall torque for example.
Your could gear them somewhere in between these two
extremes -- for example, you could choose to gear them
to match speeds when they are loaded at the level
required to break the tires free.
In every case though, you are only matching the
performance at one torque - speed point. At every
other point there will be a mismatch of some level.
Is this mismatch a disaster? I don't think so. Our
machine in Double Trouble used matching free speeds an
our robot worked just fine.
Joe J.
[IMG] code is Off
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
Speed Reduction for Drill Motors Ian W. Programming 5 18-01-2003 23:57
