Go to Post "Why do it the easy way when you can do it the hard way?:rolleyes:" - EricH [more]
Unread 15-09-2008, 08:58
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
pic: Mammoth GearBox1
Unread 15-09-2008, 09:06
REVving up for a new season
FRC #2848 (All-sparks)
Re: pic: Mammoth GearBox1
I was wondering why you are bothering to pocket the gearbox so much? Since you said this isn't for a FIRST bot, weight should not be an issue. In which case you are just using machine time you don't need to.
Also have you or anyone else with the models taken a look at the strength of those side plates? As your pocketing seems to remove quite a bit of material. Now I am not going to venture a guess as if those will hold or not as I don't know the wall thickness but generally when you remove 80% + of the material from the side the strength is just not there. Either way you or someone who knows what they are doing should look at this design. The same thing goes for your face width of the gears.
Just remember that keeping gearboxes light is nice, but don't do it at the sacrifice of gearbox performance. If the gearbox will fail it doesn't matter how much weight you loose because you wont be able to drive.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 15-09-2008, 09:22
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Originally Posted by rc_cola1323 View Post
So we needed a powerful gearbox and I decided to bring back the 3 inch cims. ]
Did you realize the small CIMs are more powerful than the big ones?
-John
Unread 15-09-2008, 10:27
Data Nerd
FRC #0079
Losing weight is always a good idea, be it FRC or the real world. But realize there is a trade off. What amount of material can you lose before your assembly is no longer strong enough to do what it needs to? Also, at what point does ease of manufacturing come into play? Im no machinist but I have a hunch that removing that much material will take some time.
What about going to a lighter material than Aluminum? I know that some teams use Lexan (least thats what I think based on my limited knowledge) Maybe look into that. I wouldn't feel comfortable cutting that much stuff out and leaving it on an FRC bot. Now, this mammoth SHOULDN'T be getting in a pushing contest with another mammoth but the saying, "rather safe than sorry" applies here.
Plus from a safety standpoint covering the whole thing makes sense, yeah optimally its going to be an internal mechanism, but kids have a nasty knack for getting into places they arent supposed to be, I wouldn't want to be the organization that has to explain to a sobbing mother why her son no longer has a finger. Covering the whole thing in a lighter material may be a good idea anyway.
Also the smaller cims are more powerful. Bigger is not always better.
Unread 15-09-2008, 11:02
artdutra04's Avatar
VEX Robotics Engineer
If you are going to make those on a regular CNC milling machine, then it would be SO much faster to fabricate by making the outside of the plates square. That way, you can just stick the plate in a vise and mill out the bearing holes and pockets (as opposed to mounting it onto a fixture plate, and mounting that inside the milling machine, then having to mill out the pockets and holes, as well as go around the outside to make the curves...).
Also, if the aim is weight savings, I would lighten the gears well before I would start pocketing the side plates to that extent. All it takes is two operations on a milling machine (either CNC or manual with DRO and rotary table) to make these. Depending on the gear size these can save quite a bit of weight.
Art Dutra IV
世上无难事,只怕有心人.
Unread 15-09-2008, 12:03
Woodie Flowers Award
Ken Patton Ken Patton is offline
purple
FRC #0051 (Wings of Fire)
Ken Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond repute
Theres some good advice on this thread, hope you are seriously considering what they said, rc_cola.
One item not yet covered - if you are going to use a sprocket on the output shaft to drive a chain drive, you should think about the shaft loads that will result from the chain when the motors are at full load and the wheels are stalled. The chain load can be pretty high for a drive with this output torque.
One other thing you might consider - the standoffs that you are using there look pretty skinny. Along with making sure you have adequate strength of the sideplates (as Greg already said), I would make sure you have enough contact area between the standoffs and the side plates.
Ken
Unread 15-09-2008, 12:31
R.C.'s Avatar
Thanks for all the suggestions:
-Pocketing the gearboxes was because we wanted to try out the CNC and with Cosmos it tells us that the plates are plenty strong enough. They are 7068 plates at 1/4 inch. So the plates are just for fun.
-The mentors were going over the specs and said that the 3 inch cims would be better for a 2 stage reduction.
Thanks everyone.
R.C.
MadTown Robotics Team 1323
Unread 15-09-2008, 15:06
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Thanks everyone.
7068? You're just playing with fun materials, rather than trying to economize, right?
And as for the big CIMs, all things being equal, it's probably sensible to get rid of those somehow.
Unread 15-09-2008, 17:42
run the trap!!!
Team Role: Human Player
I suppose you really want to make a gearbox... because a tough box with spacers weighs only 1.77 lbs...
How big is the mammoth? Will you be mechanizing the head? If you do, post some pics, since that sounds really cool!
-Philip J. Fry
Unread 15-09-2008, 17:56
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
... and if you swap out the steel 50 tooth cluster gear for the aluminum 50 tooth cluster gear, you can save another 0.31 lbs.
Andy B.
Unread 15-09-2008, 18:06
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Andy B.
What a sneaky guy we have here...
Edit: Looks promising. How's the 6061 holding up?
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 15-09-2008, 18:20
R.C.'s Avatar
The 7068 is coming as a donation from one of our near by metalshops and i'll try to get rid of the big cims.
Yeah, we kinda wanna CNC some stuff and i'll put pics up tomorrow. The mammoth is huge and the head will be moving.
Andy B.
Thanks Andy, Make sure to do that.
R.C.
Unread 15-09-2008, 18:49
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Andy B.
Well it's about time AM offered Aluminum gears! Can't wait to see how these perform.
thanks, Vivek
"we don't build robots, we build people"
Unread 21-09-2008, 00:04
R.C.'s Avatar
Man time does fly, I'll put up some pics of the actual mammoth on tuesday or monday depending on when i can get them.
Here's some the prototyped plates in plastic and prototyped wheel for next year and for the mammoth.
R.C.
pic: team 1305 - The Mammoth Ayu Robot Showcase 2 04-03-2004 23:33
