Re: Make the display board...
Posted by Mike at 1/13/2001 11:01 PM EST
Other from Grandview Heights High School. In Reply to: Re: Make the display board... Posted by Josh Vetter on 1/13/2001 10:50 PM EST: The display board is your key. As for making the valves work there is a manual override on the solenoid (it wil be a little whie or organge button) Push it and the valve shifts. You will also find in the pnuematics catalog a website called www.fpda.org and a user name and password. There you can find pnuematics people close to you who can help you (distributor locator map) Good Luck |
| Who has used pneumatic wheels? | chellyzee93 | Kit & Additional Hardware | 3 | 16-02-2003 11:49 |
| Can you stop a pneumatic pump at half shaft | mjt902 | Pneumatics | 16 | 06-02-2003 11:58 |
| pneumatic system pressure | illumanat'i | Pneumatics | 6 | 31-01-2003 00:46 |
| How can i mount a pneumatic piston to a pvc pipe!?!?! | archiver | 2001 | 4 | 24-06-2002 01:11 |
| More than 2 pneumatic tanks? | kangarue23 | Pneumatics | 10 | 01-05-2002 12:14 |
