Go to Post I'm down with banning the Chicken Dance (and take the Macerena with you when you go)! - Koko Ed [more]
Unread 12-01-2008, 23:33
eccmaster eccmaster is offline
FRC #2344
eccmaster is an unknown quantity at this point
doing double integration to getdistance traveled
Has anybody been able to do double integration with readings from the accelerometer in the kop? How do you do double integration in easy c?
Unread 12-01-2008, 23:50
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: doing double integration to getdistance traveled
At http://www.olimex.com/dev/mod-mma7260q.html there is a way to convert acceleration and time to speed, and distance.
V = A * t, then the distance S = V * t
Unread 13-01-2008, 03:29
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
The key to the integration is precise, interrupt-driven timing.
When you take the acceleometer output, you can use the formula vf = vf + (a * t) every time through the program loop. If you use precise timing, you know the set time interval, you know the acceleration, and you know the initial velocity (this was vf the previous time through the loop), so you can solve for the new final velocity.
From here, we plug this into the distance formula of df = df + (vf * t). This formula finds out how far the robot would have traveled at velocity vf for time t, and then adds that onto the previous distance.
With a dual-axis accelerometer, you will need two separate sets of these equations, one for both the x and y dimensions.
Art Dutra IV
世上无难事,只怕有心人.
Unread 13-01-2008, 04:26
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
don't forget that most accelerometers will not register the spin of your robot, that's a gyroscope...
you can use an accelerometer if you place it not at the center of rotation, with the measuring axis pointed at the tangent of the direction of rotation...
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 19-09-2008, 01:25
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Yes, I resurrected an old thread... but I'd rather do that than start a new one on essentially the same subject.
I know doing double integration blows any error in a sampling of the acceleration up very fast over time (squaring and accumulating the error each time) but, has anyone done the double integration and can share some findings?
How fast does error show up? In what way? How accurate is it?
One application I'm looking at would require the double-integrated accelerometer to remain accurate for about 100ms.
Thanks for any data you can offer,
q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Integration of Gmail and Gtalk IraJason Chit-Chat 8 20-02-2006 10:26
Accelerometer integration Leav Programming 4 27-01-2006 11:56
CMU Integration Overview???? Mumford 406 Programming 1 09-02-2005 18:17
Autonomous Camera Integration GregC Programming 2 06-02-2005 14:34
Autonomous Camera Integration GregC Programming 1 05-02-2005 18:56
