Go to Post The imperfect COTS parts you have in your shop will perform much better on the competition field than the perfect custom parts you only have CAD drawings for. - philso [more]
Unread 23-06-2002, 22:53
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Bar Height
Posted by Michael Martus at 1/14/2001 12:53 PM EST
Coach on team #47, Chief Delphi, from Pontiac Central H.S. and Delphi Automotives Systems.
In Reply to: Bar Height
Posted by Kailey on 1/14/2001 9:52 AM EST:
As per the print this dimension is to the top of the pipe. When building you must consider all the parts that are part of the construction, the 4x6, the fittings, the pipe dia. Then cut the pipe accordinally. The size on the BOM is close.
[IMG] code is Off
Grab bar on bottom of goals archiver 2001 0 24-06-2002 00:49
how effective do you think robots going under the bar archiver 2001 4 24-06-2002 00:36
actual O.D. of grab bar of goal? archiver 2001 1 23-06-2002 23:20
How many robots on the bar in one match? archiver 2000 14 23-06-2002 22:39
height questions Team461 Off-Season Events 3 29-10-2001 21:51
