| Thread Tools |
Rating:
Display Modes |
#16
Re: pic: Something is blocking the 548 display case!
Team 2028 uses ours ALL the time. Last year we used it to make the drums our forklift would wind the cable up on. The only thing to remember is to be careful, anything with less than about a 1/4 in thickness is most likely to break as we found out the hard way. Also although it may seem stupid, when printing a larger object, start it the night before, and remember to make sure you have ABS! It also comes in handy to build custom motor mounts for the Denso window motor.
#17
We have access to a Selective Laser Sintering machine. The material runs something like $100/lb. Unfortunately it is only available in 20lb buckets. That puts a 1 cuin part that weighs about 16grams at $2000. Just a little over the $400 limit. The rules do change and this is one of the sillier implictions of the previous rules. Why would we want to discourage teams from using this technology if they have it available? Let us hope for better wording in 2009. |
#18
I shouldn't have been so vague. I meant something a little more durable than the standard 3d print output. I'm assuming they're printing ABS plastic with their dimension.
ABS is already a great plastic, but the applications of it in something like FIRST are numbered. You could use the standard output in low-load, low-impact areas such as potentiometer and encoder couplers and other sensor integration applications. But as soon as they want to start making, stuff that is going to take more of a beating (mecanum rollers, custom wheels, pulleys, etc...) it would be wise to use a more durable material. Cast aluminum is heavy, but if they wanted to try cast polycarbonate, polyethylene, acrylic, etc... I'm sure they would see a benefit as well as an increase in applications for which they could use their printer. |
#19
That is nice, here is another perspective:
#20
)Anyone know about how strong printed ABS is to regular ABS sheets? Would a printed ABS transmission plate be just as strong as a machined one? |
#21
-John |
#22
Printed ABS part strength as compared to molded ABS part strength varies. It all depends on how the parts are printed, how complex they are and how large or small the features are. Also there are several different strengths of ABS for Stratasys/Dimension printers. Some ABS printed parts can have strengths of 80% + of a molded part. You are never really going to match a molded part because the layers of a 3d printed part are it's weakness.
Here are some more pictures: The miniature Dimension 3d printer pencil holder on my desk used up around $100 of model and support just to 3d print. |
#23
Yeah, but the coolness factor is up there; somewhere in between Toughbox mounting plates and fishboy on the catbell.
| pic: The Beginnings of an FRC48 School Display Case | Travis Hoffman | Extra Discussion | 19 | 11-10-2008 16:05 |
| pic: FIRST VeX Display at the New York State Fair | jt250 | Extra Discussion | 4 | 06-09-2007 23:50 |
| pic: Team 1403 School Display Case | slickguy2007 | Extra Discussion | 21 | 02-11-2006 17:03 |
| pic: Team 190 WPI blocking the bars! | CD47-Bot | Extra Discussion | 13 | 26-05-2004 19:31 |
| blocking the ramp | Jacqui Sutton | General Forum | 3 | 07-01-2003 09:02 |
