Go to Post *sigh* Anything else we can do to get this thing to work? - domoarigato [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 19-09-2008, 07:34
Betty_Krocker Betty_Krocker is offline
Fabricator/Hacker/Comic Relief
AKA: Michael
FRC #2028 (Phantom Robotics)
Betty_Krocker is an unknown quantity at this point
Send a message via AIM to Betty_Krocker Send a message via Yahoo to Betty_Krocker
Re: pic: Something is blocking the 548 display case!
Team 2028 uses ours ALL the time. Last year we used it to make the drums our forklift would wind the cable up on. The only thing to remember is to be careful, anything with less than about a 1/4 in thickness is most likely to break as we found out the hard way. Also although it may seem stupid, when printing a larger object, start it the night before, and remember to make sure you have ABS! It also comes in handy to build custom motor mounts for the Denso window motor.
"Measure once, cut twice... wait... what?"
"Two things needed to build a robot.. WD40 for the things that don't move but should, and Duct tape for the things that move but shouldn't"
Unread 19-09-2008, 13:28
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Originally Posted by Hachiban VIII View Post
I think that guy may have worked himself to death.... may want to look into that....
Does it print in ABS? I've played around with the 3-d printer at the tech shop. Its a cool tool, but the materials are absurdly expensive.
Something to remember. According to the parts rules for some previous years, you must account for the cost of materials by using the price of the smallest commercially available quantity. In this case it would be the cost of the spool of raw material.
We have access to a Selective Laser Sintering machine. The material runs something like $100/lb. Unfortunately it is only available in 20lb buckets. That puts a 1 cuin part that weighs about 16grams at $2000. Just a little over the $400 limit.
The rules do change and this is one of the sillier implictions of the previous rules. Why would we want to discourage teams from using this technology if they have it available? Let us hope for better wording in 2009.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 19-09-2008, 14:03
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Originally Posted by Alan Anderson View Post
The output of such a 3D printer is plastic.
I shouldn't have been so vague. I meant something a little more durable than the standard 3d print output. I'm assuming they're printing ABS plastic with their dimension.
ABS is already a great plastic, but the applications of it in something like FIRST are numbered. You could use the standard output in low-load, low-impact areas such as potentiometer and encoder couplers and other sensor integration applications. But as soon as they want to start making, stuff that is going to take more of a beating (mecanum rollers, custom wheels, pulleys, etc...) it would be wise to use a more durable material. Cast aluminum is heavy, but if they wanted to try cast polycarbonate, polyethylene, acrylic, etc... I'm sure they would see a benefit as well as an increase in applications for which they could use their printer.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 19-09-2008, 14:11
J SMITH J SMITH is offline
FRC #1024
J SMITH is an unknown quantity at this point
That is nice, here is another perspective:
Unread 19-09-2008, 20:36
run the trap!!!
Team Role: Human Player
Yeah that sounds about right. We've never actually made anything for the robot with it, but we've considered using it to make give aways (think micro-tube-a-saurus's )
Anyone know about how strong printed ABS is to regular ABS sheets?
Would a printed ABS transmission plate be just as strong as a machined one?
-Philip J. Fry
Unread 19-09-2008, 22:23
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Nope, the printed parts are more likely to shear between the printed layers.
-John
Unread 19-09-2008, 23:01
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Printed ABS part strength as compared to molded ABS part strength varies. It all depends on how the parts are printed, how complex they are and how large or small the features are. Also there are several different strengths of ABS for Stratasys/Dimension printers. Some ABS printed parts can have strengths of 80% + of a molded part. You are never really going to match a molded part because the layers of a 3d printed part are it's weakness.
Here are some more pictures:
The miniature Dimension 3d printer pencil holder on my desk used up around $100 of model and support just to 3d print.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 19-09-2008, 23:28
AndyB's Avatar
AKA: Andy Burchardt
Yeah, but the coolness factor is up there; somewhere in between Toughbox mounting plates and fishboy on the catbell.
pic: The Beginnings of an FRC48 School Display Case Travis Hoffman Extra Discussion 19 11-10-2008 16:05
pic: FIRST VeX Display at the New York State Fair jt250 Extra Discussion 4 06-09-2007 23:50
pic: Team 1403 School Display Case slickguy2007 Extra Discussion 21 02-11-2006 17:03
pic: Team 190 WPI blocking the bars! CD47-Bot Extra Discussion 13 26-05-2004 19:31
blocking the ramp Jacqui Sutton General Forum 3 07-01-2003 09:02
