Go to Post FIRST is difficult and it is challenging, but you aren’t necessarily required to go off and build an 8 motor drivetrain and 4 motor / 8 pneumatic piston arm mechanism for the heck of it when a 2 motor non-shifting drivetrain and 2 motor arm does just as good a job. - Bill Gold [more]
Unread 23-06-2002, 22:54
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Bridge Width Question
Posted by Gary Bonner at 1/15/2001 12:37 AM EST
Other on team #433, MINT, from Mount Saint Joseph Academy and Pew Foundation.
In Reply to: Re: Bridge Width Question
Posted by Brian on 1/14/2001 7:21 PM EST:
16-inch on center studs used in wall construction allows the wallboard joints to occur over a stud. The outer studs would protrude 3/4 inch beyond the edge of the panel. In the case of the bridge, the outer joists are flush with edge of the panel. If you then interpret the 16 inch on center dimension to apply only to the outer joist distance, that leaves 13 inches between the inner joists, the same as the diameter of the small balls. And if we have egg-shaped balls, they could get stuck there. My guess is that they should be evenly spaced, about 15.5 inches.
[IMG] code is Off
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Team 111 Picture archiver 2001 18 24-06-2002 00:50
Wedge and Solenoids archiver 2001 3 24-06-2002 00:17
Question about the bridge archiver 2001 11 23-06-2002 22:54
Using Base 36 "Compression" For Easier Scouting and Other Interesting Tidbits Adrian Wong Rules/Strategy 9 21-09-2001 20:28
