Go to Post This is a high-energy sporting event, not a piano recital. :) - Alan Anderson [more]
Unread 21-09-2008, 19:08
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
First: 2008 Batteries are D-Y-I-N-G.
I haven't seen this communicated on Chief Delphi yet, so I wanted to get this out there.
I know of three teams this weekend that had a cell/cells in their batteries die.
The battery appears to be fully charged, but when you put it on the bot it drops to 6-7 volts (or lower) very quickly. It killed a match for us, and two other teams we talked to have also had issues with the 2008 batteries dying on them.
Let's get a record going - if these batteries are indeed an issue as I believe they are, we need to get word to First so they can rectify the issue. That is a lot of money to spend on batteries only to have them die in less than a year. We've still got 2006 batteries (from the old manufacturer) that are working!
Unread 21-09-2008, 19:12
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: First: 2008 Batteries are D-Y-I-N-G.
We had this happen also, it says it is fully charged but as soon as you start the match it goes to 6-7 volts. Also we lost of our playoff matches that we could of won. BTW, the batteries are getting really hot, it melted the pneumatic tubing, there is no short on our whole board. We double checked.
R.C.
MadTown Robotics Team 1323
Unread 21-09-2008, 19:13
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
At the beginning of the build season, the TechnoKats tested everyone of our batteries from previous years and from this year, and the ones from this year had mid to low range on them. I found this weird as we have batteries dating back to 2001 and we have never had problems with them. Also when we did the test, last years were the strongest! That was shocking to me that 1 year old batteries were stronger than new batteries from the same manufacturer.
I win! XD
Unread 21-09-2008, 19:14
ATannahill ATannahill is offline
AKA: Alex Tannahill
When were they charged? Usually always they will show 12 when doing nothing, no matter what the real voltage. If you try to do something they will jump to the right voltage.
Unread 21-09-2008, 19:41
Tom Line's Avatar
They were charged. We're not using the somewhat...lacking... charger from first either - we're using a far better one. No - this is definitely something going on with the batteries. It's nice to see other folks reporting the same thing.
We know the standard rules - you don't put them on concrete, never overcharge them, don't let them sit with no charge on them at all, fully discharge them before charging them again...
Unread 21-09-2008, 20:27
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
... batteries ... We know the standard rules - you don't put them on concrete, ....
Unless the cases are unusually conductive, or there is a significant thermal gradient between the top and bottom of the batteries when they are placed on said concrete (or whatever they might be resting upon), I think you can stop worrying about putting them down on concrete. See the page at this URL
http://www.thebatteryterminal.com/Te...n_Concrete.htm
Unread 21-09-2008, 21:19
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
Wow - glad you posted this.
1 of our 2008 batteries is doing very poorly. I figured we dropped it or something.
Brian Graham
Unread 21-09-2008, 21:26
psyco_klown's Avatar
psyco_klown psyco_klown is offline
aka Shawn Burgen
FRC #0839 (Rosie Robotics)
psyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to beholdpsyco_klown is a splendid one to behold
well First did give us new chargers this year. We found that that there was a 6v charge or a 12v charge buttons and if u barely touched the button it changed the mode.
Shawn Burgen-FRC Team 839 Mentor
Team 839 FTC Mentor
Unread 21-09-2008, 21:59
Libby K's Avatar
Libby K Libby K is offline
Always a MidKnight Inventor.
FRC #1923 (The MidKnight Inventors)
Rookie Year: 1992
Libby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond repute
Our 2008 batteries aren't holding charge well either. One of them flat out doesn't work, and the other is pretty bad.
Libby Kamen
Team 1923: The MidKnight Inventors
2006-2009: Founder, Captain, Operator, Regional Champion.
2010-Always: Proud Alumni, Mentor & Drive Coach. 2015 Woodie Flowers Finalist Award.
229: Division By Zero / 4124: Integration by Parts
2010-2013: Clarkson University Mentor for FLL, FTC & FRC
FIRST Partner Associate, United Therapeutics
#TeamUnither | facebook, twitter & instagram | @unitherFIRST
questions? comments? concerns? | twitter: @libbyk | about.me/libbykamen
Unread 21-09-2008, 22:12
DonRotolo's Avatar
Back to humble
FRC #0832
NO! Absolutely never, ever do this!
Lead-acid batteries are not like NiCd or NiMH batteries - a full discharge to a lead-acid battery will significantly shorten the life of the battery.
DO keep them charged all the time, recharge them immediately, don't let them sit all summer discharged. A charge in a gel cell will last 60-90 days before it's a problem.
Don
Unread 21-09-2008, 22:31
Here's a thread from earlier in the year about this: http://www.chiefdelphi.com/forums/sh...ad.php?t=66541
Unread 21-09-2008, 23:17
BT987's Avatar
BT987 BT987 is offline
FRC #0987 (High Rollers)
Team Role: Human Player
BT987 has a spectacular aura aboutBT987 has a spectacular aura about
we had problems at IRI, but it turns out our charger was broke, so before you get rid of your batteries check to see if it the charger. It cost us like three matches.
-2009 Las Vegas Champions(1622 and 1013)
-2009 Las Vegas Chairmans winner.
-2008 IRI Champs(330,67,68)
-2008 Arch. finalists
-2008 Vegas winners(39 an 1013)
-2008 Vegas chairmans winners
-2007 World Champions! thanks to 190 and 177
-2007 Vegas Finalist
http://www.team987.com/
Unread 21-09-2008, 23:59
For you who have had battery problems, the absolute cause comes down to a variety of issues. I have been in contact with the manufacturer who is testing batteries using the same charger supplied by First. To date they have not reported anything out of the ordinary. Teams should not compare MK batteries with previous years as they are different in construction. There is a difference, between gell cell batteries and the MK AGM batteries. It would appear that the MK batteries are a little more sensitive to shock and mishandling. The hotspots in a battery case are likely the result of two or more plates in a cell being forced together by this rough handling. The result is a short in that cell. Heat is an indication of high current flow. AGM batteries are also sensitive to overcurrent charging. Charge currents higher than 6 amps cause the plate structure to deform also resulting in cell shorts. This is also true of batteries that are stored at high temperature or repeatedly put on charge without rest. Allow batteries to cool before returning to charge following a match. I have also noted many teams who lift and carry the battery by the leads. The battery is not designed for that and internal damage is the result. If you have team members who practice this method, suspect that as one of your causes.
Finally, all batteries have a finite life cycle. First batteries since 2001 all have been about 400 charge/discharge cycles max. Repeated high current discharge (i.e. full discharge in a single match) shortens this life by half or more.
Unread 22-09-2008, 01:25
run the trap!!!
Which charger? The new one ('08)?
How did you know it was broke? Lights but no charge?
-Philip J. Fry
Unread 22-09-2008, 01:38
KF987 KF987 is offline
AKA: Keaton
FRC #2034 (IncrediBULLS)
KF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud ofKF987 has much to be proud of
Send a message via AIM to KF987
We were experiencing problems every other match at IRI and we kept checking our electronics but could not find anything wrong...
we told Cory from 254 and he told us they had similar problems in the past... he told us to check the charger... we took the charger out of the rotation, and didnt have any more problems the rest of the competition. The charger had no visible signs of failure, or malfunction. Cory really helped us out!
I believe it was an 08 charger.
Keaton
**FIRST EMAIL**/Call for Proposals - 2008 FIRST Robotics Conference Mark McLeod FIRST E-Mail Blast Archive 6 21-12-2007 09:35
**FIRST EMAIL**/2008 FIRST Scholarships Available Mark McLeod FIRST E-Mail Blast Archive 1 08-11-2007 12:00
Where did first get the Edu Batteries hedgehogger General Forum 7 28-02-2004 01:09
What are some things that you associate with first or the FIRST regionals? A. Snodgrass Chit-Chat 12 24-02-2003 02:13
