Go to Post you are going to gear that down right? Otherwise your robot will take about 10 minutes to reach its top speed of mach 2.6. - M. Hicken [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Unread 19-09-2008, 17:58
yarb65 yarb65 is offline
Coach
AKA: T Bray
FRC #3189 (Circuit Breakers)
yarb65 has a spectacular aura aboutyarb65 has a spectacular aura about
Re: an unusual observation
No in CA we call it a cone zone.
2013 Sacramento Regional Winner (3189,701,2489))
2012 Israel Regional Winner (1662,1690,1937)
2008 Sacramento Regional Winner (1662,115,2122)
2006 Sacramento Regional Winner (1662,852,1726)
Unread 20-09-2008, 10:25
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
Cone Zone with Barrel Bullies.
Object of the game is to find a retrieve cones launched into the playing field and stack them in your home zone. Bonus if you cover your cones with a large traffic barrel.
Format Change:
All bots at a regional play at the same time to truly get that traffic jam level of frustration. Matches extend from the typical 2 minutes to 20 minutes, but there will only be 2 minutes of moving spread out over the 20 minute period.
Unread 20-09-2008, 13:01
Format Change:
Double the bonus if you can stop Albert the Road Barrel from moving your stack...
Unread 20-09-2008, 14:02
Dick Linn's Avatar
no team (Synergy)
You'll need at least a few robots designed to wave a traffic flag or lean on a shovel in the end zone to play the cone game.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 20-09-2008, 14:10
Onward through the fog.
It wouldn't be right to leave out the caution saw horse whose only purpose seems to be to partially block a closed lane, or rather, open lane, adding confusion when it is supposed to add direction and flow. The traffic flag laying on its side could add to the direction/flow/confusion/blockage - then the caution saw horse would serve its purpose, fully.
I think.
~ Helen Keller
(1880-1968)
Unread 20-09-2008, 21:48
IKE's Avatar
IKE IKE is offline
AKA: Isaac Rife
no team (N/A)
I think.
so do saw horses wear horse shoes?
Unread 20-09-2008, 22:50
Althewierd's Avatar
Althewierd Althewierd is offline
AKA: Alex Yuen
FRC #0836 (Robobees)
Althewierd is an unknown quantity at this point
though the last few years have seen the main object as a ball, it isn't any less likely to be a ball this year. The ball is a fundamental piece of many internationally acclaimed games and hundreds more unofficial.
On the subject of the game, every year I think, "how can they ever make it better than last year?" and every year, they do.
Unread 20-09-2008, 22:58
As a matter of fact, that is not the case. Take a good look at the games for the past several years. I can only think of one time there's been two or more "ball" games in a row, and that was 2000-2002. Since then, crates, balls, tetras, balls, pool tubes, balls. Before then, similar pattern.
Analysis indicates that we're due for a non-ball year.
Unread 21-09-2008, 10:36
Althewierd's Avatar
AKA: Alex Yuen
that's a good observation but whether or not there was a ball last year for the game does not affect whether or not there is a ball this year. Its all up to FIRST.
Though, I do hope the pattern stays true.
Unread 21-09-2008, 15:36
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
I was thinking frisbees might be fun.
At any rate, I'm hoping for something we have to launch into the air.
EDIT:
We could be required to skip a frisbee-like gamepiece off water. Say each gamepeice has a name printed along the rim, and we have to skip each gamepiece accross the water a number of times before we can let it sink to the bottom of the pool. Points would be allocated for skipping the gamepieces, but most of the points would be in sinking the gamepiece at the appropriate time. The autonomous period at the beginning would be dredging the frisbees out of the bottom of the pool (the pool would only be a meter in depth).
-- Marshal Horn
Unread 21-09-2008, 16:37
I was remembering that earlier this year, Dave posted a picture of a glass of water on a pair of Mars bars. Twice. That must be a...
...Game Hint!
Unread 21-09-2008, 16:41
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
...Game Hint!
You wish......it probably had more to do with the discovery of water on Mars!
Jon Mittelman
Senior Judge Advisor New England & Israel 2014-2015
Infinite Loop Mentor 2011-2015
TechnoTicks Mentor 2000-2011
Championship Chairman's Award 2009 Team236 TechnoTicks
Judge 2010-2015 Championships
Senior Judge Advisor New England District Championship 2014-2015
Judge Advisor Tel Aviv Regional 2007-2015
Judge Advisor Pine Tree Regional 2013
Maine Regional Planning Committee
New England District Planning Committee
Lead Inspector Microsoft Tel Aviv Regional 2006-2008
Judge & Lead Inspector GM/Technion Tel Aviv Regional 2006
Judge UTC Hartford Regional 2006
Unread 21-09-2008, 18:16
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
Aha! Confectionary contest! I like it!
-- Marshal Horn
Unread 21-09-2008, 18:35
haha!
Well, we'd have to round them up.
(Thought you threw me a curve, didn't ya? )
~ Helen Keller
(1880-1968)
Unread 21-09-2008, 19:22
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
There has been a pattern? Awww, crap. Now we have to start the design all over again....
-dave
Unusual amount of stickers Skifanatic Kit & Additional Hardware 1 10-01-2007 18:05
An Observation about the Team Updates and Manual Ryan Foley General Forum 3 10-02-2005 11:01
Observation about Selecting Alliances Kel D General Forum 14 13-05-2004 07:43
unusual parts Dstiebel OCCRA 11 09-11-2002 23:38
Unusual robot archiver 2000 13 23-06-2002 22:45
