Go to Post You know you've been involved with robotics too long when you see a remote-controlled traffic barrel coming up behind people and honking - and it doens't faze you. - GaryVoshol [more]
Unread 23-09-2008, 09:30
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Programming with the 2009 controller
NI has been pushing their LabVIEW tools into the embedded world for a few years now and they really seem to be gaining traction. There are already cRIO and sbRIO solutions and you can even get a variant of LabVIEW called LabVIEW Embedded with ports for ColdFire, Blackfin and ARM on your own custom PCB (including the Luminary Micro controller in the new Jaguar motor controller).
Such high-level tools (eg LabVIEW, Matlab/Real-Time Workshop, UML) will never compete with machine code, assembly or C/C++ (or other similar text-based languages) in terms of code efficiency. However, a good engineer knows when to use which tools. Sometimes you need to partition a design team and leverage their individual capabilities (eg use a combination of languages with high-level state machine "programming" and low-level drivers for code size/speed). Sometimes you need to get a product out the door as quickly as possible (often made easier using high-level tools) and are willing to pay a few extra $ for a microcontroller with a little extra oomph.
Russ
Purchasing the 2009 controller Tottanka FRC Control System 60 04-05-2008 19:44
How the heck do you use an XBOX360 controller with the chicklet?? waialua359 Control System 58 17-02-2008 12:43
Problem with the program downloaded to the controller itsme Programming 9 14-01-2007 12:12
Problem with the 2005 controller Guy_E Programming 10 18-12-2006 01:38
Programming The CMUcam for the Vex controller 987HighRoller Programming 3 24-06-2006 15:27
