Go to Post And if in the end the students are inspired and more of the public becomes aware of the program, and people gain more appreciation for engineering, how can that not be a good thing? - dlavery [more]
Unread 23-09-2008, 16:18
kajeevan kajeevan is offline
FRC #0188 (blizzard)
kajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud ofkajeevan has much to be proud of
Programming help for the non-programmer
A couple of my classmates and I are participating in the Skills Canada Competion and we need help with electical stuff. We want to use some of the vex parts and motors and we want to use the vex microcontroller so we can program an automode into our arm function. But the problem is that we can't use the vex controllers, we have to use Park Flyer Controller unit (2.4GHz Spektrum DSM; 6-channels). So is it possible to connect that reciever/controller into the vex mircocontroller so we can use their controller. Or are there some other uncomplicated ways of accomplishing this.
http://www.horizonhobby.com/Products...odID=SPM2460BR
this is the controller site.
Help much appreciated.
Unread 23-09-2008, 19:05
dtengineering's Avatar
dtengineering dtengineering is online now
AKA: Jason Brett
Re: Programming help for the non-programmer
First of all, don't assume that you cannot use the VEX transmitter and receiver. Although I can't find this year's Skills Canada rules on line anywhere, I have read them and they seem pretty similar to last years. Page 14 specifies ground frequency transmitters OR the Spektrum, and I believe this year's rules are the same. The VEX transmitter and receiver use ground frequencies.
The real catch, however, is that as you say the VEX cpu is probably not allowed as it would likely constitute a "complete, out of the box" system, specifically disallowed under Skills Canada rules. This is where knowing, for sure, that a STAMP or Arduino is allowed would come in handy. (This might sound odd for those used to FIRST competitions, but Skills Canada works under the "student designed-student built" philosophy, has no KOP and specifically disallows teachers and mentors from entering the pit area for instance.)
But don't count my advice as to the rules... ask a question of the organizing committee... can you use the VEX Transmitter and Receiver? Can you use the VEX Transmitter and Receiver and CPU? Can you use the VEX CPU by itself? How about a BASIC Stamp or an Arduino (they might be allowed as a general purpose board, rather than a complete out-of-the-box solution)?
If the answer is, as you suspect it may be, "No" to all of the VEX related questions above, then you will probably have to come up with your own control system. The important thing for us to know in order to help you is what functions do you want the controller to have? There is no autonomous component to the competition, and most Skills robots are directly radio control... sometimes complemented with an on-board controller that responds to onboard sensors, as opposed to responding to the remote control inputs.
So check out what you are allowed, and give us a better idea of what you specifically want to do.
Jason
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Programming Help For The Noob thevexkid VEX 8 04-09-2006 18:27
Building a programmer for the VEX... t0ny127 FIRST Tech Challenge 4 29-06-2005 23:32
Non-traditional prepping for the regional..... archiver 2001 25 24-06-2002 01:32
Help for New Programmer Mike375 Programming 3 27-09-2001 09:04
