Re: an unusual observation
I was along the same lines. Another option is to make random notes of music in the same way that the Boston subway stations around MIT do -- large wind chimes.
*ears perk up* - are there any photos or links that tell about this? It sounds cool.
Some random dude's 3 minutes of youtube fame Also, apparently (blog link) there are levers to control the chimes, a gong, and sheet metal. |
On a different note, using chimes as targets (or actuated by targets) is brilliant! You could even have a marimba-type thing (with a resonating chamber). |
How about a giant funnel, like those things that marbles spiral down? (line the rim with chimes and keep the lazy suzan in the center) The gamepieces would be those little blue racquetballs that team 128 was handing out at nationals. Near the base of the chimes there'd be a shield to hold the balls in and keep them from bouncing all over the place; instead letting them roll down the funnel (maybe in a spiral). The goal would be to throw the balls up and hit the chimes (more points for certain interval sequences). Getting hit by your opponents balls (when they're on the ground) would give them points. Firing balls at an opponent would be penalized. As your balls are rolling down the funnel, you should try to pick them up. The "spout" of the funnel is just a recession that makes it more of a pain to collect balls (encouraging teamwork). Since this might require a ceiling, there could be a giant gong (suspended horizontally) in the middle of the ceiling, where you get special points if you hit it. You are also awarded those points if you fire some balls on top of the gong, and someone else knocks them off by firing at the gong.
Now what could Autonomous be? (thus the problem) |
#7
We've had robot basketball and nascar..
'07 was kind of like "Tic-tac-toe." Now comes...Soccer? Maybe Scrabble? Yes, robots moving huge tiles under time! It would use shape-recognition, at least for autonomous . |
#8
Tic-tac-toe was 2005; 2007 was Connect 4. Hmm...board game, sports game, board game, sports game... Uh-oh.
#10
Woot! New patterns are emerging!
#11
Monopoly!
Checkers! Chess! |
#12
We could have water bombs!
Water Game+Board Game... Now all we need is a fire game! I know! on an allience we would have one fire fighter bot, one bomb droper, and one platform bot that would have to have bombs droped on it butalso do the platform thing that we did in 07, and then for your team to get points your bot has to not be on fire at the end but it and you would also get points for being on the platform but if the other allience drops bombs on the fire fighter bot they get major penaltys and vice versa this will never happen but atleast it would make robotics less nerdy.... we mght get some outsider fans too....h |
#14
We have a stretch of Interstate 295 around Richmond that is so cratered and patched that when you drive over it, it seems to play a tune. It's hard to make out, but I think it's "Don't know whose rear-end is gonna fall off first - mine or the truck's". It's an old blues tune.
| Unusual amount of stickers | Skifanatic | Kit & Additional Hardware | 1 | 10-01-2007 18:05 |
| An Observation about the Team Updates and Manual | Ryan Foley | General Forum | 3 | 10-02-2005 11:01 |
| Observation about Selecting Alliances | Kel D | General Forum | 14 | 13-05-2004 07:43 |
| unusual parts | Dstiebel | OCCRA | 11 | 09-11-2002 23:38 |
| Unusual robot | archiver | 2000 | 13 | 23-06-2002 22:45 |
