Re: None of our radios work!!!
Only the obvious causes:
--When the OI radio is swapped with the RC radio, i.e., the OI radio gets mounted on the robot instead of the RC radio. --When the team number doesn't match on the OI and RC, but tethering them first so the RC can learn the OI set team number avoids that and it sounds like you tried that. --Really, really poor radio antenna placement or a disconnected antenna broken inside the housing, but that'd feel loose. --Low battery or power on either the RC or OI, but the OI power supply and a charged robot battery avoids that. --Serial cable connections loose or bad or one of the cables has gone bad. Try replacing the two cables connecting the radios. --Another set of radios broadcasting on the same channel, but changing channels would have tested this. --Master Code v13 or higher If you have your older 2007 robot with the same radios you can try communicating with the radios used for that to see if you can isolate the problem to the robot or the OI radio. Last edited by Mark McLeod : 24-09-2008 at 17:09. Reason: Adding things as I think of them... |
| pic: Our Machinists hard at work (with one posing) :) | redbarron | Extra Discussion | 9 | 19-01-2008 15:05 |
| Radios | Pnakovich | Inventor | 5 | 18-11-2007 13:53 |
| Still trying to get our new sticks to work, please give a hand! | raptere | Control System | 2 | 13-03-2005 01:08 |
| Minor Problem, our robot DOESN'T work! | Cobra | Motors | 1 | 15-02-2003 14:43 |
| And then there were none... | Joe Johnson | General Forum | 2 | 21-10-2001 23:31 |
