Go to Post I don't know about you but i would love to have a grilled cheese maker in the workshop. - CMBrandon [more]
Unread 26-09-2008, 18:21
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Re: Programming with the 2009 controller
Closest thing you'll get is the Guide that one of the team members of Team 1817 has done about programming a National Instruments Compact Rio (NOT THE FRC VERSION).
http://www.team1817.org/cRio_report.html
If the code there intimidates you, be assured that programming the 2009 NI CRio FRC will be much more easier. From what I understand right now, there will be many demo VIs (programs in LabView) that will explain how to program in LV and program a robot in LV, and hopfully, teams will recieve/download a default code(or VI) for LabView which with it teams can control a robot like you would with the Default Code for MPLab in previous years, just that you will have much more options of changing values easly in order to:
- Chose the method of driving the motors (1 joystick, 2 joysticks, omni....)
- Defining input/output for analog and digital components
- and probablly much more!
and all that without having to create too much of your own code.
So I think the best thing for teams (same goes for teams that are looking forward to use only C/C++) to do now is to understand how to use LV to program a robot (know how to use shortcuts, values, loops, statments etc...) so once you receive the robot controller and Labview (hopfully) with the Default Code, you'll be able to change the code to fit your robot easly.
TEAM 2230 ZECHARIA'S ANGELS
2009 Microsoft Israel FRC Regional Winners!
2009 Microsoft Israel FRC Regional Chairman's Award Winners!!!
2008 Microsoft Israel FRC Regional semi-finalist.
2008 Microsoft Israel FRC Regional Delphi's "Driving Tommorow's Technology" Award winner.
2008 Robot Driver
2007 GM/Technion Israel FRC Regional semi-Finalist.
2007 GM/Technion Israel FRC Regional Xerox Creativity Award winner.
2007 Robot Driver.
Purchasing the 2009 controller Tottanka FRC Control System 60 04-05-2008 19:44
How the heck do you use an XBOX360 controller with the chicklet?? waialua359 Control System 58 17-02-2008 12:43
Problem with the program downloaded to the controller itsme Programming 9 14-01-2007 12:12
Problem with the 2005 controller Guy_E Programming 10 18-12-2006 01:38
Programming The CMUcam for the Vex controller 987HighRoller Programming 3 24-06-2006 15:27
